Originally Posted by s24789
I have changed plans yet again on panel lighting. Looking for guidance on a dimmer. I already have a 50K 2W pot I was going to use for another option. I am switching to an under the glareshield LED option. The LED lights only draw 83ma at 12V. Is this pot useable or do I need a dedicated dimmer system. Thank
Kevin
Several years ago I designed a PWM dimmer circuit for someone, and if you're interested I could dig it out. One of the considerations you should make about your lighting is this, are you going to make the positive or the negative voltage source common to the lights and control the other source. I recommend that you make the negative source common and control the positive. That way if the common lead gets shorted to the airframe there is no problem, and if the positive lead is shorted it will pop the breaker.
