Does changing the D-100 battery erase the memory?
Last weekend, I replaced my defective HS-34 module with a new one from Dynon. I also changed the D-100's battery while I had it out and after I finished, it read DSAB connectivity error...or something similar, and the 430W would not show on the D-100's HSI and had a 'no arinc 429 signal detected'.
Will changing the battery erase the D-100's memory? It also said 'no HS-34 installed' when it was installed. Ray re-programmmed the D-100 and now all is fine but I'm curious.
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
