07-25-2010, 08:24 PM
Main Spar Countersink Priming?
What do most use as primmer on the wing main spar countersinks; rattle can primer, alodine pen, etc? I am using Sherwin Williams two part on other surfaces and rattle can NAPA for spall parts.
John Johnson
Murphy, NC
RV7
07-26-2010, 02:01 AM
I just used some leftover primer from a priming session and dabbed each countersunk rivet hole on the main spars with a Q-tip.
07-26-2010, 08:49 AM
Ditto on the Q tip...
Sprayed rattle can etch primer onto qtip and coated the exposed aluminum countersink. Tried just spraying the hole but that was too messy. Couple dabs with a saturated Qtip did the trick.
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2020
07-26-2010, 09:09 AM
I plan to countersink through painters tape, hoping this will work fine
07-26-2010, 09:47 AM
Make sure you adjust your counterskink cage to account for the thickness of the tape - I suggest punching a few holes in scrap first.
07-26-2010, 02:39 PM
Alodine. The c-sinks are small enough that dabbing on alodine with a small "acid brush", it will form a meniscus due to surface tension. Let it sit for a few minutes, then wipe down with a wet paper towel and blow it dry.
Came out looking like perfect next to the anodizing on the spar.
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
