Old 07-24-2010, 02:38 PM
kevinh's Avatar
kevinh kevinh is offline
Default Plane Power alternator dying?
Hi ya'll,
I'd like to request diagnostic assistance:
I'm on the way to OSH and noticed an odd thing: normally my master bus voltage is 13.6. However, on the last leg of my flight it dropped to 13.2 and then 12.9. I was like 'uh oh' - I have an ebus, but wasn't looking forward to swapping alts at OSH.
So I started turning things off. As soon as I turned off the autopilot servos, it went back up to 13.6 (yay! alternator working again). Later in the flight it started to creep down to 13.4. Then I turned off strobes and it went back up to 13.6.
So, is my alternator dying? I'm thinking it is unlikely a connections problem because lowering the draw allows the current to stay up. (Also, if you are thinking this is due to the ~.6V drop from the e-bus diode, my voltage is measured from the master fuse bus)
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 07-24-2010, 03:10 PM
n468ac's Avatar
n468ac n468ac is offline
if you are close to C09 Morris, IL ... i would be happy to meet you at the airport and you are welcome to use our tools to look into it.
chris @ checca.net
(This post by: Christopher Checca EAA Lifetime Member #799388)
Allen Checca (father)
Christopher Checca (son)
RV-6A - N468AC
ENGINE: Lycoming 180 HP O-360-A1A
PROPELLER: Senisentch 72FM859-1-85
WEIGHT: Empty Aircraft 1152 lbs
BASED: KC09 - Morris, IL.
Flying since June 6, 2005
N468AC Web Site
Old 07-24-2010, 03:28 PM
Jamie's Avatar
Jamie Jamie is offline
Why is your master buss voltage at 13.6 normally? It should be hovering around 14 volts, no?
Old 07-24-2010, 07:44 PM
kevinh's Avatar
I would have thought the same (expecting 14.2), however back when I switched to a PP alt it was 13.6 - I had presumed that they bumped the regulator down a bit compared to automotive uses. Anyone here have a PP alt and can report what their normal voltage is?
Of course - I'll call em on Monday from OSH or hopefully they are there.
Old 07-24-2010, 08:06 PM
AltonD's Avatar
AltonD AltonD is offline
my PP runs 14.2 volts.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 07-24-2010, 08:19 PM
kevinh's Avatar
Thanks Alton, Chris and Jamie!
I'll give em a call on Monday.
Old 07-24-2010, 10:56 PM
AirbusPilot AirbusPilot is offline
In my 8 endurance bus read 13,6 Volt with PP Alternator, but this is because I feed this bus from main bus with a diode.
Just my 2 cents
Fernando Abasolo
Santiago Chile
SubSonex waiting for tailkit to arrive
Flying phase II RV-8 (SCSE) Serial Number 83290, Tail Number CC-AJC
Flying RV-8 (SCTB) Phase II 600 hours and counting since February 22nd 2010
Serial Number 82727, Tail Number CC-PXG
Lyc. IO-360, Hartzell Prop
VAF #2056
EAA Member 774981
Old 07-25-2010, 08:23 AM
Jim Percy Jim Percy is offline
My PP alternator is rock steady at 14.35 volts- I know this because my EIS is constantly going back and forth between 14.3 and 14.4 volts...
Jim Percy
SoCal
FFI Wingman
RV-7A, XP-O-360
Old 07-25-2010, 08:44 AM
Radomir's Avatar
Radomir Radomir is offline
Mine's 14.3-14.4V...always.. never seen it below that. I'd think that 13.6 should work, but it's kinda on the lower end of the scale...
Radomir
RV-7A sold
Old 07-25-2010, 04:46 PM
kevinh's Avatar
I did some more testing this morning. It is 14.2 volts at the master bus and the EIS (which is on the ebus so behind a diode) slows 13.6.
The dynon is on the master bus and I don't know why it has started bouncing around all of the sudden. When it is a bit cooler I'll make sure the connection it has to the master bus is good. But now that the mystery is solved I can investigate more at home.
