Old 07-22-2010, 05:59 PM
snoopyflys's Avatar
snoopyflys snoopyflys is offline
Default Looking for Blind/Pulled Rivet x-ref to Solid Rivets
For those times when one misses a rivet or two and can no longer access it with a squeezer / bucking bar, I was wondering if anyone has a cross-reference for using a pulled rivet to replace a solid rivet? For example, what type of blind rivet would I use to replace a AN426AD3 or an AN470AD3 solid rivet?
Dan Schultz
=VAF= Annual Paid Subscriber
VAF #1446
Slow Building - 7A Tipper
Old 07-22-2010, 09:18 PM
RV6AussieNick RV6AussieNick is offline
Generally you cant replace a solid rivet for a blind rivet because of strength, you can go stronger but not weaker, however for the odd rivet here and there I'd suggest using a Alloy Cheri Max rivet, I cant remember the full part number. I'm sure someone out there will know the part numbers.
Nick.
Old 07-23-2010, 05:52 AM
According to Vans, the MK319-BS blind rivet is acceptable to replace and AN426AD3 rivet. In fact, according to the RV-6 manual, you can use these for the entire bottom wing skin (I wouldn't though). Vans doesn't use an AN470AD3 rivet anywhere.
EDIT: If you go to the Aircraft Spruce website, they list the ccc-32 as an interchange for MK319-BS, it isn't. The ccc-32 is a smaller diameter and doesn't pull well by comparison. Good for nutplates and stuff like that, but I wouldn't use it for a structual application.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
