Gday
Can anyone tell me if i split the output (gray/Voilet)wire from my skyview SV-250-GPS reicever will this give the adi the info it needs to make the heading display work or will the ADI not except this info??
Paul Austin
Tasmania Australia
RV7A
I made a similar question on the Dynon forum a while ago. The answer is that the GPS antenna is not a simple receiver as for a VOR, for instance. I was suggested to use one GPS antenna per unit OR to send the SkyView the signal needed for position and timing via the GNS430W.
I don't know if the ADI has an output signal for feeding the SkyView. If I well remember, the answer is no.
