Old 02-26-2006, 02:54 PM
Scott Cutler Scott Cutler is offline
Default primer solenoid mounting
Looking for ideas on how to mount the fuel primer solenoid from Van's. Anyone got pictures?
Old 02-26-2006, 03:07 PM
Rick6a's Avatar
Rick6a Rick6a is offline
Default primer pics
There are a couple of ideas and pics on this page.
http://www.vansairforce.com/communit...ead.php?t=4463
Old 02-26-2006, 05:31 PM
painless painless is offline
This is how I did it. Used two adel clamps on the motor mount.
It is quite firm and not prone to vibration at all.
Regards,
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 02-26-2006, 08:53 PM
RV_7A RV_7A is offline
and my sensors on the inside...
-Jeff
www.JeffsRV-7A.com
N808TX
Old 02-27-2006, 08:57 AM
vlittle's Avatar
vlittle vlittle is offline
The advantage of the location I chose, is that the bracket is mounted to a stiffener angle (at least two rivets are). It's also an easy run from the gascolator.
You don't want it vibrating and work-hardening the copper tubing, which can crack.
Vern Little
