12-06-2010, 10:07 AM
I like to keep between 35-40 PSI in the nose wheel with this tubeless design.
In the tube style wheels (Matco/Grove) I would keep 40-50 PSI normaly.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
12-06-2010, 03:10 PM
Walt, why the difference in pressures between the two wheels?
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men? for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
12-06-2010, 04:33 PM
In my experience low pressure in tube tires will cause tube failures so I always keep them at the upper end of the scale.
12-06-2010, 05:39 PM
Ahhh, gotcha. Knew you had to have a good reason!
Highest Regards,
Noah F, RV-7A
02-07-2011, 06:33 PM
Anybody with a Beringer nosewheel have any problem fitting the nosewheel fairing? When I put a 5/8 spacer above the wheel and put the wheelpant on, as the manual indicates, the fairing sits way too high. I wonder if the diameter of the tire on the Beringer wheel is a little bigger than the Vans standard?
Highest Regards,
Noah F, RV-7A
02-28-2011, 06:43 PM
Originally Posted by GrayHawk
Try the people who made Wonder Woman's plane. I think they are out in the LA area somewhere.
That's got to be the ultimate in glass panels.....
Dave
03-01-2011, 04:10 PM
My wheelpant fit just like always when I replaced my stock nose wheel with the Beringer.
I would be hesitant to have less than 5/8" clearance between the wheel and tire.
03-01-2011, 04:15 PM
It uses the same tire so there should not be any difference.
03-01-2011, 04:37 PM
Too bad they didn't make her costume too!
 CJ
The experiment works!
11-14-2011, 10:55 AM
comparing ACS & Beringer
ACS is now showing a "Nose wheel 5" with tire 11x4.00-5" 8ply and aluminum axle" which seems to correspond to the SRV02A in the Beringer catalog. The ACS listing below that ("Nose wheel kit as described above, with Michelin Aviator Tire 5.00-5" 10ply Tubeless Weight: 8.9 Lbs") seems to imply an optional different wheel & tire, but according to the Beringer catalog, that one is actually for the RV-10.
They are priced in the Beringer catalog at $558 and $649 (RV-10) USD, and $730 and $720 (RV-10) at ACS.
Brian Meyette, Cornish, NH
1995 RV-6A - N16RK (Ralph Koger) SOLD
RV-7A - incomplete, supercharged Subaru STi - N432MM - SOLD
2001 Quad City Challenger II LW - N28RT SOLD
www.meyette.us/RV-7Ahome.htm
