Old 07-14-2010, 06:54 PM
rjcthree's Avatar
rjcthree rjcthree is offline
Default Wire labeling, post installation.
For wire labeling, I had a good plan that isn't working, I'd like some help on plan B.
I planned on using my brother labeler and making flags. It suited my needs, as I saw them, I'm a minimalist when it comes to labeling. All the labeling is to be done post-installation. I can't get the labels to stay as flags. The pop open -they stick to the wire, but not to themselves.
Sooo, labeling already-installed wires is the task. I researched 6:1 shrink, but it's not available in clear, and I really don't want to (won't) disconnect everything anyway to label it.
Thanks in advance for any ideas you may have.
Rick 90432
ps, anybody want to help me get on the gear this weekend?
Old 07-14-2010, 07:44 PM
Transporter Transporter is offline
Default Wire Labels
Steinair carries wire labels; look under accessories for "wire marking card":
http://steinair.com/accessories.htm
3M also makes a set of wire marking dispensers; available in colors and numbers, and write on tags:
http://www.mcmelectronics.com/produc...9653-/108-3222
The 3M products really stick on the wire and resist solvents. Not cheap but they get the job done.
Good luck,
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Old 07-14-2010, 09:28 PM
Kapton tape has an amber color, but is transparent enough to see labels through. That tape is the bust stuff for electrical. It can take high temps, is chafe resistant, and the adhesive on good tape lasts forever. I have used it for years and it is awesome. We used that stuff all over satellites where I used to work. if it can handle space travel, it should do fine in the RV. Of course, make sure you buy a good brand of the tape.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 07-15-2010, 12:22 AM
erich weaver's Avatar
I used the Dymo Rhino labeler. Tape is tough and the text can automatically be repeated on the label so that it can be viewed from any angle. Would work great after completion of wiring too.
Erich
