View Poll Results: Did you paint your plane yourself?
Did you paint your plane yourself? 31 55.36%
Did you have your plane painted commercially. 12 21.43%
If painted yourself, would you do the same again? 30 53.57%
If painted commercially, would you do the same again? 11 19.64%
Multiple Choice Poll. Voters: 56. You may not vote on this poll
Old 07-14-2010, 04:01 AM
tomhanaway tomhanaway is offline
Default Did you paint your plane yourself?
As I get closer to deciding, I'm very curious as to what everyone did.
Feel free to post comments if that helps clarify.
Old 07-14-2010, 04:46 AM
plehrke's Avatar
plehrke plehrke is offline
I voted that I painted myself but a more accurate description is that I did all the prep work and my hanger-mate, John, did the taping and spraying (with me in the booth operating the rotisserie). We made the spay booth in our hanger. John has painted several other planes so thought it best to have him spray which was a great decision (although John could not have just stood by and watched me do it myself).
So, no I did not have it professional done but I did not do it all myself either.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 07-14-2010, 04:51 AM
I painted mine myself and am very pleased with the results. The process, however, was miserable - probably the most frustrating part of building the airplane.
Of course, this was the first thing I ever painted, so I had a steep learning curve. Which brings up a key comment - practice on something else first - your buddy's beater pickup, a set of lawn furniture, etc. Its kinda silly to spray the first $100 pot of paint on an expensive item like an airplane when you could learn just as much without getting frustrated by spraying el-cheapo paint on something less important.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 07-14-2010, 04:57 AM
pierre smith's Avatar
Default Yes and no...
...my building partner and I have two professional autobody painters/repairmen for friends.
We did the sanding, prep and priming. When it was all masked and sanded, one of them came by on a Thursday evening and sprayed one color. Then, the next week, after we had re-taped and masked for the second color, he came by again....turned out really nice...base coat/clear coat,
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 07-14-2010, 05:04 AM
RV8R999 RV8R999 is offline
I concur! I just completed painting my -8 myself and wholeheartedly agree it was the single most frustrating part of the build process but I wouldn't have done it differently (except I'd use a different paint). I'd painted before but never with the Stewart System paint, so I might as well have never painted previously.
Honestly, my paint job is OK. Not really up to my standard but not horrible either. Luckily, the stewart system poly can actually be buffed to a remarkable shine so I've got a little work to do once the paint fully cures in about 30 days.
If you use Stewart and you have a dark top coat I recommend you do not use their white primer but use the darker charcoal grey instead. The top coats are very very very translucent and you'll never be able to get the full color in only 4 coats with a white base - this led to 90% of my frustration as more than 4 coats would run like crazy if sprayed too early or orange peel if too late (no way to tell when to early or to late was). I ended up shooting 4 coats, letting it dry, Then shooting an additional 4 coats in exactly same process. Way to much work.
Good luck!
Old 07-14-2010, 06:00 AM
Sheldon's Avatar
Sheldon Sheldon is offline
I painted my 6A myself.. Yes, lots of work.. Didn't come out as good as I would have liked, but wet sanding and buffing made it better.. The sanding & buffing was a big job too... A learning curve there also... Even so, it was worth it... get lots of comments on it.. "You painted it yourself..?? WOW..!" As I'm wiping it down, making sure my rag is over the run part..
Sheldon Barrett sheldonb@frontiernet.net
RV6A 0-360 FP 750 hrs
Champ RV6 at LOE #3
Old 07-14-2010, 08:58 AM
aerhed aerhed is offline
Wow, that's a lot of coats. Like doing lacquer. There's no way I can lay 8 coats without screwing up. I'll stick with good old Poly-U. My experience with "waterbornes" has been almost infuriating. Anyone remember the Blue River products? Yuck.
Old 07-14-2010, 09:03 AM
Bill Wightman's Avatar
Bill Wightman Bill Wightman is offline
I did paint my RV4 myself, but had access to a professional paint booth. Things like ventilation, lighting, cleanup, support materials - all were in place for me. Without that support, I don't think I'd try it on my own.
?The important thing in aeroplanes is that they shall be speedy.?
- Baron Manfred von Richthofen
RV8 under construction
RV4 - Sold
United B777 FO, Chicago
Aero Engineer
RV8
Old 07-14-2010, 09:34 AM
Jim P's Avatar
Jim P Jim P is offline
I covered and painted my first aircraft using PolyFiber process, but I farmed out the RV to Grady at GLO Custom. It's not my favorite thing to do but if you do paint it yourself, it's certainly a huge sense of accomplishment.
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 07-14-2010, 09:47 AM
Jimd Jimd is offline
Default Painted It Myself
I voted painted myself and I would do it again.
A LOT OF WORK, but very satisfying! The worst part for me was all the glass prep, so if you think your going to do that part anyway I say you might as well shoot it also, if you have the area to do it.
I had painted two pickup trucks back in highschool nearly 35 years ago so I feel like I had basically no previous experience. I used a simple homemade plastic booth, sprayed the floor with water and used an average gun with automotive enamel for the entire process.
YMMV
Jim D.
RV-6
RV-10 tail kit 50%
(When do I get to measure something?)
"Flying north of the Arctic Circle and back - several thousand dollars,
Doing it in an RV you built yourself - PRICELESS!"
