07-11-2010, 11:27 AM
Need source for #30 & #40 drill bits in bulk
Anybody know of a good source for those particular two drill bit sizes that will let you buy in bulk at a discounted price? Seems like every company I?ve ran across wants you to buy one to two in a package, or buy an assortment of drill bits with every size imaginable, while not letting us concentrate on our particular sizes we need. Any leads would be appreciated.
Thanks.
07-11-2010, 11:45 AM
Senior Curmudgeon
I bought mine from either Cleavland or Avery-----maybe both.
Call them----both really good folks to work with.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
I do not know the answer to your question but I, too, like to have sharp drill bits so I purchased a bit sharpener. Specifically, I acquired the higher end Drill Doctor (750x, I think) which can be set for greater angles than normally found. This allows me to sharpen and split the points on all my dull bits and provides me a way to modify bits for plexiglas work. I have about twelve bits in each size and just put them in a container when they're dull and sharpen them all at a single session. (Takes about three or four minutes a bit.)
I hope this suggestion is of use.
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL, A&P
Frederic.magare "at" gmail.com
 RV-9A Firewall Forward
[Engine purchased]
07-11-2010, 11:49 AM
Ditto. I'm sure they will sell in whatever quantity you want. I know at least one of them has bags of 6ea #30s and #40s ready to go.
07-11-2010, 11:52 AM
been here awhile
Thanks.
Clevealand Tools has them in packages of 6:
http://www.cleavelandtoolstore.com/products.asp?dept=19
Comes out to a little over a dollar per bit.
07-11-2010, 12:07 PM
Yard Store.com cobalt #30 $1 ea. #40 $.80 each
07-11-2010, 12:40 PM
Send me a list.
Send me a list with any and all desired qty's
I am a factory direct distributor for Precision Twist Drill!
These are only MADE IN AMERICA
Tech page is http://www.gen-aircraft-hardware.com...pdf/drills.pdf
07-11-2010, 01:23 PM
Brown Tool will do it.. they even had discounted prices listed in the catalog...
Radomir
RV-7A sold
07-11-2010, 01:37 PM
Harbor Freight
Harbor Freight sells them in packages of 10 (they are just labeled in fractions) for cheap. Dave
07-11-2010, 01:54 PM
McMaster-Carr
Always good for quick delivery - can be pricey though.
