Old 07-05-2010, 09:25 AM
mikehoover's Avatar
mikehoover mikehoover is offline
Default Where did you mount your Red Cube (fuel flow)?
Where did you mount your Red Cube? Regrets? Comments? Pictures?
Thanks!
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 07-05-2010, 12:01 PM
Mel's Avatar
Mel Mel is offline
Same place I had my FloScan for 16 years. Under my left knee, between the fuel selector valve and the boost pump.
Works great!
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 07-05-2010, 01:37 PM
prkaye prkaye is offline
On my firewall (engine side), near the bottom, pilot's side. Plumbed immediately upstream of of the carb.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 07-05-2010, 02:48 PM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default red cube
in the #6 line between the engine driven fuel pump and the carb!
Seems to work great so far.......but only about 20 hours in it!
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 07-05-2010, 03:37 PM
Walt's Avatar
Walt Walt is offline
When I had the carb I had it after the elect boost pump in the cabin.
Switched over to FI and put it between the servo and the spider.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 07-05-2010, 03:47 PM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Hi Phil - do you have a picture? I was figuring to mount it in the line from the engine driven pump to the carb... but trying to determine if hanging in the line or hard mounted to the firewall would be better. If hard mounted, I'd like to do that now...
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 07-05-2010, 04:00 PM
Brantel's Avatar
Brantel Brantel is offline
Mine is between the engine mounted pump and the carb mounted on the firewall with a piece of heavy angle... The bolts holding the angle intersect the cross brace of the firewall.
Once I zoned in on the correct K factor, mine is now accurate to withing a tenth at fillup....
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 07-05-2010, 04:32 PM
apkp777's Avatar
apkp777 apkp777 is offline
I mounted mine just downstream of the gascolator. I am not liking that. I am planing on moving it to the aft side of the firewall downstream of the elec pump.
Brantel - How did you find your "K" factor? I have mine set at the factor 68,000.
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 07-05-2010, 05:32 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
In my 6A, the floscan is just past the electric fuel pump, along the left sidewall, as this is where the lines were routed in the six. If I ever change to a Red Cube, it would be installed in the same place. Since the elec. fuel pump isn't used much, the overall effect on the fuel meter, when filling up is miniscule.
I don't especially like the idea of having these units hanging between the engine pump & carb fitting. Nor the front firewall area because of heat & fire sleeves.
L.Adamson --- RV6A
Old 07-05-2010, 06:24 PM
Flybuddy2's Avatar
Flybuddy2 Flybuddy2 is offline
Mine is in the same place (just past gascolator) and works poorly there. Don't know why Dynon recommends that location. Everything else I read says to put it just upstream of the carb. Difficult place to install directly in line though as distance is too short. I've ordered new hose and fittings and intend to move it to left side firewall and run hose from mechanical pump to it and then in to carb. The Floscan may be better if you want to mount in line as it's smaller and lighter.
