Old 07-05-2010, 05:58 AM
Bob_pipedream Bob_pipedream is offline
Default Mainspar bolts in the RV-6
Hi all,
About a week away from the end now, but stuck on the main spar bolts (the bigger NAS ones). I think they are NAS 1105 with the short thread and when I put on the nyloc nut, the thread is only just long enough to come out the end of the nut before the nut bottoms out on the shoulder of the bolt. Note -this is without installing the bolt in the main spar but with bolt in my hand, so this not a washers issue.
These are all standard Vans issue and will not give me 1.5 threads sticking beyond the nyloc nut.
Any ideas/comments?
Old 07-05-2010, 11:04 AM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Sounds like you got the wrong bolts. I'd measure everything on the bolt with a digital caliper especially threaded length, put the nut on and take a pic to send to Van's. Then give them a call. Is it possible they included the wrong bolts? Maybe...
HTH
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 07-05-2010, 11:20 AM
RV6AussieNick RV6AussieNick is offline
Measure the shank of the bolt in 1/16ths, not including the threaded part, does the drawing give you a bolt length..??
Or you can use a grip length gauge to measure the spar, splice plate thickness and compare that to the bolts you have.
You should ad a 1/16th to the length for the washer under the head..
Good luck..
Nick..
Old 07-05-2010, 01:35 PM
GAHco's Avatar
GAHco GAHco is offline
Cool NAS Bolts
Here is some good information about NAS Bolts.
http://www.gen-aircraft-hardware.com...pdf/nashhb.pdf
This should answer most of your questions.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
