07-04-2010, 09:30 AM
Prop Governor Cable Bracket
Can anyone tell me if the Van's bracket VA-153-PC will fit on a PCU5000X governor? The info on the Van's Web Store site says it will fit an MT or a Hartzell governor. I have acquired an old bracket of unknown heritage from a neighbor and the three screw holes are just a bit off from the holes on my PCU governor.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
07-04-2010, 09:55 AM
Yup
I had to grind a little bit off the inner radius and elongate one of the holes, but I got it to fit without too much trouble:
07-04-2010, 10:05 AM
Thanks Jason. I think I can do the same with the bracket I have. I did notice that the inner radius would have to be opened up a bit, as well.
David Maib
RV-10 N380DM
VAF Paid 1/21/2020
Jackson Browne
07-04-2010, 12:20 PM
I shimmed it so it's just slightly above the radius.. so there was no interference and no need for grinding..
Radomir
RV-7A sold
07-04-2010, 02:34 PM
Not the best fitting bracket
I too had problems with the fit.
After grinding away and elongating the mounting holes it fit but I had to grind down the head of the linkage bolt to get it together.
I wasn't happy with the end result so I made my own bracket for my RV-7A (see other postings by searching PCU5000). Fits great and don't have to mess with a modified bolt arrangement.
Your mileage may vary
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero- HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
07-05-2010, 07:43 AM
Thanks Paul,
Your bracket looks great.
David Maib
RV-10 N380DM
VAF Paid 1/21/2020
Jackson Browne
07-05-2010, 09:30 AM
cut back with new holes
with a forward mounted governor i needed to make sure to have enough clearance from the cowling with my control linkage coming over the top... i cut mine back to clock it slightly differently and drilled new holes. with my bracket arrangement the standard governor clocking, shown in the photo, is reversed. not a problem to switch, but it had to be done by the manufacturer, aero technologies.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
07-05-2010, 10:00 AM
Governor bracket
David,
The bracket I used needed to be refitted by drilling new holes for mounting to the governor and also grinding some to create clearance for the pushrod tube and fuel line to the #2 cylinder. otherwise the cable bracket won't clear the top engine cowl on the -10.
Don
N410JA
07-05-2010, 10:19 AM
Senior Curmudgeon
Originally Posted by midwest rv-10
David,
Don
N410JA
Just curious here, why are you trying to put the cable above the engine, when the factory setup is below???
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
07-05-2010, 10:41 AM
Governor cable bracket reroute
Mike,
David and I have A/C so the original mounting and routing of the cable has to be moved to allow mounting of the A/C compressor.
Don Orrick
N410JA
