Old 07-03-2010, 03:46 PM
mikemalone mikemalone is offline
Default 4-way Work Bench
I can't seem to find any information on the small work bench that some builders have used to mount 3 or 4 power tools. It was maybe 24 x 24, on castors.
Old 07-03-2010, 06:49 PM
Skybolt Al's Avatar
Skybolt Al Skybolt Al is offline
Default "Sportplane Builder"
by Bingelis, page 40.
Al
RV-9A
Allen@AllenRice.net
Started 7/09
First flight 7/8/2015
Love this plane!!
Old 07-04-2010, 08:20 AM
jarvis jarvis is offline
24 x 24 is not big enough. I believe mine is 36 x 36--on the road, can't measure or remember. It is full with vise, belt sander, band saw, and grinder. I used Bingelis guidance for overall approach, but you want BIGGER castors with at least two brakes. I also mounted small 1 gal vacuum on the vertical 4 x 4 in the middle--very handy. Power cord runs to the top of that 4 x 4 from auto-return reel in center of shop ceiling. Good piece of gear--great space saver--saves lots of steps.
Jarvis
Purchased flying RV-7A
RV-7A emp finished, wings next.
Old 07-04-2010, 08:36 AM
GrayHawk's Avatar
GrayHawk GrayHawk is offline
For those of you that have them, how about some photos? A picture is worth a thousand words.
I built a 4'x4' version (canopy, dimpling) , but will need to run out to the hangar to take a photos, will post later.
GrayHawk
My rebuild log: http://www.cherryfamily.net/bill/n63tx/rebuild/
Texas Hill Country Hangar For Sale: http://www.myspicewoodhangar.com/default.htm
Old 07-04-2010, 08:55 AM
esjacoby77 esjacoby77 is offline
Here's mine...I just used the EAA 1000 workbench plans, modified the dimension, and added wheels. I believe the surface is roughly 30x30. It has worked well for me, but I would like it to be just a little bigger.
Old 07-04-2010, 12:37 PM
Flyguytki's Avatar
Flyguytki Flyguytki is offline
Mine is built the same way as the eaa tables and is 24x36. I am able to access all sides so I have tools facing out on all sides. I have a band saw drill press, grinder, belt sander and a vice. Here's a link to a few pictures
http://www.n87dx.com/N87DX/Shop.html.
It now has a shelf added as well.
-David
RV-7 N87DX Built, Flown, and Sold!
Old 07-05-2010, 04:40 PM
Thanks to all. My first post and problem solved!
Old 03-30-2011, 12:08 PM
SilverEagle2's Avatar
SilverEagle2 SilverEagle2 is offline
Default Based on the suggestions here
I know this thread is a little older, but in a search it may come in handy to others to come.
Based on others suggestions here, I constructed my 4 way bench from the EAA concept and added an old Server Rack Power strip to the underside.
Originally I had a 2' X 4' made from the left overs of my 4' X 6' work table. It is now my table for my DRDT-2.
The shelf will hold my chargers for battery operated tools and perhaps a radio.
It is a 4' x 4'
I have younger curious children so I needed something to keep the tools from falling over on them. Each is bolted to the table.
I may add a little shop vac underneath as well for shaving collection from the sander and band saw.
See what happens when you have time waiting for kits to arrive!
Jason Hess
N777JH - Reserved
RV-7 - Builders Log Tail complete, wings nearly done, starting fuselage!
RV Factory - Complete sans floor coating, Slideshow Here
People are not excellent because they achieve great things; they achieve great things because they choose to be excellent.
Gerald G. Probst, Beloved Grandfather, WWII B-24 Pilot, Successful Businessman
