I plan on using the ground power plug to be able to jump start the aircraft, so I ran a 12 inch long 8 AWG ground wire to the longeron, which is my main ground point for both batteries.
If you are just using it for avionics ground power then the ground tabs plate should be fine.
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
