06-28-2010, 06:18 PM
Air filter broke in flight
Hi Folks,
Anyone have expirience this kind of air filter failure in flight???
Please give me some advise I don't want it to happens again.
Uploaded with ImageShack.us
Fernando Abasolo
Santiago Chile
SubSonex waiting for tailkit to arrive
Flying phase II RV-8 (SCSE) Serial Number 83290, Tail Number CC-AJC
Flying RV-8 (SCTB) Phase II 600 hours and counting since February 22nd 2010
Serial Number 82727, Tail Number CC-PXG
Lyc. IO-360, Hartzell Prop
VAF #2056
EAA Member 774981
06-28-2010, 07:07 PM
I've never seen one do that before.
As a guess, it would seem that you had a backfire...probably at startup.
Timothy Cone
Sierra Skypark (KE79) Fresno CA
RV-8, XP360, RV200
Flown Sept. 12, 2007
1600 hours on the hobbs and loving it
Reason: another thought
06-28-2010, 08:03 PM
been here awhile
Originally Posted by AirbusPilot
Hi Folks,
Yes, looks very much like the filter in my buddy's IO-360-powered RV-8 after a backfire during a hot start. It managed to blow the filter all the way out of the plane one time.
06-28-2010, 08:04 PM
Sure looks like a backfire to me. Do you have a sniffle valve?
Terry F.
RV 7A N457RV
250 hours and lovin it!
Southern Nevada EAA Chapter 1300 - www.eaa1300.org
Paid VAF 03/17
06-28-2010, 09:04 PM
Yes I have a sniffle valve.
How can a back fire destroy the filter and not to damage the fiber glass snorkle
How may I prevent this to happens again????
Fernando Abasolo
Santiago Chile
VAF #2056
EAA Member 774981
06-28-2010, 11:22 PM
A back fire doesn't mean Fire comes all the way back to the filter. Back fire just means fuel/air mixture burned somewhere within the induction system. This produces a lot of pressure just like it does within a combustion chamber. If the pressure is high enough it can blow out the filter.
As for preventing it... I have been flying RV's with fuel injection and a snorkle for more than ten years and I have never had a backfire. With that being said it could be your starting technique or an issue with your airplane (or even a little of both).
First place to look...If your engine has two standard magnetos and only one of them has an impulse coupling (typically the left one), make sure your ignition switch has the grounding bar installed for disabling the non-impulse mag while starting. If you have an impulse and a non-impulse mag and you are using separate toggle switches for the mag switches, make sure you are only switching on the impulse mag for starting (switch on the non-impulse mag after start).
Scott McDaniels
Hubbard, Oregon
06-29-2010, 08:09 AM
Here is my hot start technic (from lycoming manual)
Mixture ICO
Throttle Full
Boost pump off
Just left Magneto ON (the one with impulse coupling)
Cranck
Once engine fire
Mixture rich
Throttle idle
Magnetos both ON
This technics works every time, I have try some other with the throttle in different position than full, because I have read here full throttle technics could be dangerous but I have been not able to start the engine and I have run out of battery.
Please give me some advices
Fernando Abasolo
Santiago Chile
VAF #2056
EAA Member 774981
06-29-2010, 09:30 AM
Fernando,
I use the exact same technique with the exception that as I crank I start pulling the throttle to idle. At some point (usually about half way) it starts. The idea is that by pulling the throttle to idle, the engine finds a position that the air/fuel mixture is just right for starting.
Hope this helps.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
06-29-2010, 11:47 AM
Check timing of magneto's
Fernando,
I had the same problem on an RV-8 with an IO-360 M1. When I started it the first few times the engine backfired and blew the filter element out of the filter box. It also happened during a flight. It turned out that there was a timing problem with one Magneto. The points were broken (brand new mag). Once the magneto was repaired and timed properly, the problem went away.
Dan Miller
RV-8 790 hours
06-29-2010, 12:28 PM
Filter broken from holder
I had this occur serveral times and I attributed it to a backfire. I ended up putting a screen over the filter to prevent it bending and subsequently pulling out of the bracket holding it in place. I think my starting technique has improved as this occurred when I first started flying my plane, I am confident the loose screen keeps the filter in place regardless.
Steve Anderson
RV 7A Flying
130 hours
Lafayette, La.
