Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
  #11
Old 07-29-2010, 05:40 PM
N427EF N427EF is offline
Default MVP 50
Mathew Sharp,
how can this be set up with an MVP-50?
IO-540 1Mag and Lightspeed ignition?
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 08-08-2010, 02:18 PM
B Cunningham's Avatar
B Cunningham B Cunningham is offline
Originally Posted by B Cunningham View Post
James,
Can you post what your EIS settings you are using to make this work with the new modification? ie High/Low Pulses per Rev 1/2.... etc.
anyone know?
Ben Cunningham
RV7 N701VF
Bowman Field, Louisville, KY
Old 08-08-2010, 02:34 PM
jclark jclark is offline
James,
I would if I had them handy.
The plane is in another state. :-)
I am sure that they were either in the directions or that Sandy told me over the phone.
I recall it being a non-issue after talking to her.
James
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
Old 08-09-2010, 09:47 AM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
Default Tach Gen too
There is also the encoder that goes into the tach drive that Vans sells but getting the drive cable length right and mounting the sender can be a hassle. Also, the instructions that Rocky Mountain Instruments sends on their version of the EIS shows using two capacitors to a common signal line to their device instead of the toggle. I don't know how that would work with electronic ignition. but considering the different number of pulses mentioned earlier in the thread that would probably not be a good solution.
I'd probably get my EIS upgraded but $100 seems too steep. Does anyone on VAF know if it is software only or hardware change too?
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 08-09-2010, 10:22 AM
Its a hardware change too that requires you to send your EIS to Grand Rapids. I have done that, but now cant seem to get the settings right in the box. If anyone has broken that code please post... (One slick, one Lightspeed Plasma II)
Ben Cunningham
RV7 N701VF
Old 12-07-2010, 07:02 AM
anyone have their EIS settings for this?
Ben Cunningham
RV7 N701VF
Old 12-07-2010, 07:17 AM
Walt's Avatar
Walt Walt is offline
Originally Posted by N427EF View Post
Mathew Sharp,
The EI MVP 50 accepts both mag and LS inputs, the connections and settings are detailed in the manual.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 12-07-2010, 07:48 AM
I am looking for the settings for the EIS 4000 Grand Rapids for dual tach inputs -- one slick mag, one Lightspeed II.
Ben Cunningham
RV7 N701VF
Old 12-07-2010, 07:58 AM
RV6airplanePilot's Avatar
RV6airplanePilot RV6airplanePilot is offline
Default EIS 4000 settings
Settings are Tach P/R = 1 for the mag with mag pulse wire connected to EIS yellow wire on pin #12( use the resistor per manual 27k ohm).
The Electronic ignition is connected to pin 24 yellow/grey wire. Set that code to 2 and I believe it is on the set up as either N1 or N2 I can not remember // correction// the current version has a field in set up for "Tach2P/R". The display screens use a field name "Tach" which will display RPM from Tach1 if available and in it's absence will display Tach2. If you want to display Tach2 rpm specifically use field name "N2" in a user definable page. You may need to set sensitivity to high for the Lightspeed, especially if you cheated and did not use a shielded wire as Klaus calls for. I used the shielded wire and my tach2 input reads OK on low sensitivity.
Last edited by RV6airplanePilot : 12-09-2010 at 06:40 AM. Reason: Corrected info on N1 & N2 function
Old 12-07-2010, 12:16 PM
Thanks Dale!
Ben Cunningham
RV7 N701VF
