  #11
Old 03-01-2006, 09:24 AM
Davepar's Avatar
Davepar Davepar is offline
Also, I can't remember if I read this or talked to Brad about it, but yes we will be able to update the firmware and maybe tweak some parameters on the E/P-mags via the serial port. That will be a cool feature--much better than sending them back for updates. They already have a jumper to set aggressive vs. moderate advance (for high compression pistons or auto fuel) and grounding the p-lead before vs. after applying power turns on a mode where the ignition doesn't fire for the first 3 revolutions. That's to clear out any gas fumes that might be lingering in the sump. It sounds like a very flexible unit.
I was planning on using a 3 position switch (off, p-lead grounded, power + p-lead grounded) for each P-mag, but now it sounds more flexible to just have separate switches for the p-lead and power. Or maybe just break down and get a Cessna-style ignition switch plus two separate power switches.
By the way, the link to the latest manual is at the bottom of this page:
http://www.emagair.com/113.htm
Dave
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 03-01-2006, 10:54 AM
Highflight Highflight is offline
Originally Posted by Davepar
Vern,
If it helps get the P-mags to Mattituck sooner, I'd be happy to switch spots with you. I'm not sure if I'm ahead of you on the list or not. As long as I get my 2 P-mags in the next month or two, it doesn't matter to me. It sounds like you need to get the units to Mattituck pretty soon for them to build with them.
Dave
Thanks Dave, but I think I'm already set up for an earlier ship time. In fact, Brad told me about 2 weeks ago that mine would be shipped by now (end of Feb) but he's moved that back just a couple of weeks in order to get them programmed with the updated performance curve before shipping.
I checked with Mahlon at Mattituck and he's fine with putting the engine back in the schedule a little bit in order to wait for them. Originally, my engine was scheduled to be ready to ship in the second week of April so there's still plenty of time for everything to come together, and if Brad gets the Pmags shipped out in two weeks from now as expected (???), then the engine won't have been delayed hardly at all.
RV7-A - Slider (QB Fuse and Wings)
Mattituck IO-360 (AFP) w/2 P-mags
Catto 3-Blade
SJ Cowl and Plenum
Panel: Dual GRT EFIS / EIS4000 / PMA8000B / SL-30 / SL-40 / Internal GRT GPS / GTX 327
Old 03-01-2006, 05:26 PM
srv srv is offline
Default ugh
This doesn't install much faith in these guys. People have to send their new units back and the manufacturer is worried about features when they can't get the basic product out the door...
I would readily pay a premium for this product if I could have a guaranteed date. I can't have a $25K engine sitting around for months waiting for one part.
Old 03-01-2006, 07:45 PM
13brv3's Avatar
13brv3 13brv3 is offline
I got a call from AeroSport today (mostly asking what color I wanted my engine). They are expecting my Emag/Pmag, to be shipped to them in about a week. Hopefully, it will be close to that.
RV-8, SN-80587, built, flown, sold.
RV-3B, SN-10751, rotary engine, built, flown, sold
RV-8, SN-82470, built, flown, sold.
RV-3B, SN-11351, purchased, , flown, sold
A&P - 2018
Old 03-01-2006, 08:21 PM
walter's Avatar
walter walter is offline
Talking
FWIW, I ordered mine early December, got a bill for the entire enchilada
(2 p-mags) and paid by check on 12/17, they don't take plastic, which
is absolutely positively stupid. Called 3 times so far asking about my
delivery date. Last call they said to call back at the end of this week
and see but there was a slight chance that they might ship end of this
week. Ahhh, yeah, riiiiight. When pigs fly. Don't get me wrong, I
would love to see a flying pig.
Walter Tondu
Flying RV-8A - Fastback, IO-390, G3X Touch, 74 HRT
Prior RV-7A Build Log
Old 03-01-2006, 08:47 PM
casper casper is offline
Default Timing, overadvance
You do not want to experience what I have been through with these over advancing mags.
Doyle Reed, Casper 2
Old 03-01-2006, 10:20 PM
walter's Avatar
Yes we DO. Tell All my friend. One of the reasons I decided to go with
the p-mags was that I could control the advance, something I cannot
do with the LASAR. Even if I have to run at the base timing (26 BTDC)
to keep the CHT lower it's all worth it. Especially when you consider
that the maintenance (supposed) of these units is nothing compared
to a standard Mag. Please let us know of the issues you have run into.
Also, were the issues resolved? Support is a critical factor.
Walter Tondu
Old 03-02-2006, 12:35 AM
chuck chuck is offline
Default PMag experiences after 20hrs
I'm running a P-mag and a slick mag right now. So far so good, I only have about 15-20 hrs on it. I don't have any performance metrics. Most of the issues I've had have been my own doing and believe it or not changing at the last minute to the 3 position switch has been a headache. I got everything in and it works fine though there are a lot of extra connections with the 3 switches. At one point I counted and I think there are about twice as many.
The 3 position switch system doesn't have a way to set the timing without jury-rigging it. I think there is a new schematic running around with yet another switch. When I decide I have time to put in a second pmag I'll change it to work off a breaker and a switch (just like the directions say) rather than the 3 position switch. The problem with the 2 position switch is that the a breaker needs to be cycled on every flight for a generator check and the breakers aren't really designed for that...
My last issue is that I cannot get the tach signal to make my vision microsystems tach work. That's frustrating because I'd love to get rid of the big mechanical tach assembly. I'm hoping to drag a 'scope out this weekend to troubleshoot.
One thing that I notice that is not intuitive if you look at the current draw diagram for the pmag is that when doing a 'generator check' (switching off power to the pmag at > 1500 rpm) you get a stumble for a short period. This surprised me since the docs seem to say that at higher RPM's the generator makes enough power to make it go. A call to emagair straightened me out basically saying that my mental model of the system was too simple.
The install support has been great with very fast email turn arounds. Yes they had delivery problems and if that is going to be a problem then don't buy'em yet. Once you get them they seem to operate as advertised and have excellent support.
FYI, they only took 100 bucks from me and then billed the rest on shipment.
Chuck
PS One of the problems they've been having is on systems with the ryton 'plastic' sumps. If you have one of these you need to make sure you have the newer software that skips a few cycles before making sparks. Without this update it is possible to ignite the fumes in the case on the 'wasted spark' and crack a pretty expensive hunk of plastic.
Old 03-02-2006, 06:10 AM
Scott DellAngelo Scott DellAngelo is offline
I also want to add in here for the naysayers that they did tell me when I ordered mine that it would take a while and would not even give an expected date (other than should be by the end of the year). They did miss that, but not too badly. Also I would rather have to send the thing back to get something tweaked rather than them saying it's too hard and not even doing it at all.
Scott
Old 03-02-2006, 08:19 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Emag/Pmag My Experience
ECI IO360 with Whirlwind 200RV Propeller. One Emag one Pmag.
Set up and installation was very easy. I used a 5 amp breaker for the Emag and a 5 amp switched breaker for the Pmag. Timing took about 10 minutes total with another 30 to get everything locked down.
As of today, I have 52 hours on the plane and the system has worked flawlessly. This is an extremely smooth combination that I'm very happy with. My cutoff point on the Pmag is 680 rpm, well below the 850 rpm I have set up on the engine. I have had no CHT issues at all as some others have described.
The only real issue I have is during a mag check the Pmag drops 160 rpm while the Emag doesn't drop. The Pmag drop is consistent each time. I have checked all wiring and did in flight checks and all seems fine. I plan to send them in for a "once over" when I break down for paint
Regarding, the supply and delivery, I was given a time frame in which they met. I was not ready for them when they were ready to ship. I told Brad to ship them to someone who was ready and slide me down on the schedule. I got them, when I was ready, a couple of months later.
This is a new product. Other than a few isolated performance issues, I think that these have as good of track record as any other new product. (Dynon comes to mind in the early days). The important thing is how issues are handled. Brad is responsive and committed to having the finest product available and eventually have some on the shelf ready for delivery. Most importantly he is communicative and not afraid to admit the delivery shortcomings.
I'm having great luck with mine. I sincerely hope they get the delivery issues worked out so more of you can experience the simplicity, ease of installation and performance of the Emag/Pmag system.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
