Old 06-28-2010, 01:15 AM
Camillo Camillo is offline
Default Request advice on MAP & RPM order
Hi.
I installed a Dynon SkyView as EFIS and engine monitor.
My building partner is worried of having no engine information, should the SkyView quit.
So, we (he) decided to put one additional MAP indicator ( IE VMP35 )
and one additional RPM indicator ( IE VTACH3500 ) from Van's web store. We will go with 2 1/4'' ones.
I already have a clear tube from firewall to Dynon transducer for MAP. So, I guess I can intercept it and just place a tee (from Spruce?).
What will I also need? Only a transducer IE VTACHGEN 2 for tachometer? Is this the cable which will go inside the engine?
Thanks.
Camillo
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
Old 06-28-2010, 05:43 AM
dedgemon's Avatar
dedgemon dedgemon is offline
Yep just tee it in there. The tach sensor goes on the tach pickoff on the engine.
The good news here is that WHEN the vans gauges fail, you'll have the skyview to fall back on.
Or you could pull them out and use the space for something useful.
David Edgemon
RV-9A N42DE
RV-8 N48DE
whats next ??
Track me!
Old 06-28-2010, 06:37 AM
Thank-you, David.
But when Van's says that a tachometer needs a transducer, do they intend - and do IE VTACH3500 is - the cable and the terminal which goes in the appropriate slot in the engine?
Flight time: 1 hour
www.rv4.it
ROME, Italy
Status: SOLD
http://nuke.rv9.it
Old 06-28-2010, 07:51 AM
pierre smith's Avatar
Default Yes, Van's tach needs a transducer...
...and it is IE VTACHGEN 2 if you do not have a vacuum pump.
It is IE VTACHGEN 12 if you have a vacuum pump. It is indeed the unit with about a 12" cable that attaches to the tach drive on the engine and produces pulses that are sent to the tach,
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 06-28-2010, 04:41 PM
No, I don't have a vacuum pump. I guess the cable will attach directly on the RPM slot between magnetos. I will order that transducer, so.
Thanks.
Camillo
Flight time: 1 hour
www.rv4.it
ROME, Italy
Status: SOLD
http://nuke.rv9.it
Old 10-14-2010, 04:15 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Vans tach transducer
I just installed this unit-----piece of cake.
There were no instructions included------so here is a bit of info for those who follow on.........
Wiring is standard Black to ground, Red to +12v, and White is signal.
I am using the unit to drive the GRT tach function, and this requires the pulses per revolution be set-----magic number is 8.
Photos to follow.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-14-2010, 05:11 PM
rvbuilder2002's Avatar
Photos to follow.
If anyone else ever mistakenly doesn't receive the installation sheet, you can find a copy on Van's web site here.
Scott McDaniels
Hubbard, Oregon
Old 10-14-2010, 06:19 PM
gasman gasman is offline
Will this unit last longer if mounted on the firewall?
Old 10-14-2010, 07:09 PM
Mike S's Avatar
Senior Curmudgeon
Default Thanks!!
Scott, thanks for the link------however it is of no use for what I was doing, as I am driving a GRT eis input with it. That is why I posted the info here, for other folks who may be using something other than the Vans tach.
I am sure for others who are using the unit with the Vans tach, this is good to have info.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 10-15-2010, 08:32 AM
RV383 RV383 is offline
I installed an MGL single 3-1/8 digital display that indicates both RPM and MAP (also has hobbs/maint. reminder etc) as a backup. It is a great unit and easy to install and planned it as a backup to the EFIS but I prefer to use this as a primary indicator.
