Geekdom
Mike's points are correct. The only clarification is that the heat transfer from radiation is a function of the difference of the absolute temperatures to the fourth power, among other variables. One of those variables is a parameter called a shape factor, which basically says, "how much of the sphere around me is at the hot temperature?" The skin of a muffler is probably in the 5 to 700 F range (guessing), but it is not a huge percent of the oil cooler's "sphere". I.e., most of what the oil cooler sees is not hot. Another is the surfaces' respective emissivities. A totally black body is considered to have an emissivity of 1 (interestingly, water is also nearly 1, as is white paint). I've learned that it is not easy to guess at something's emissivity - light colors are not necessarily lower. The higher the emissivity (1 is the maximum), the higher the rate of transfer. In other words, don't paint the oil cooler - polished is better!
Regarding humidity's affect on convection (air through the oil cooler), I'd expect also very little. At an extreme dewpoint of 80F (which rarely occurs), the air is only about 3% water vapor. While water molecules are lighter than the predominate nitrogen molecule, water's specific heat capacity is a bit higher than nitrogen. I didn't do any calculations, but I'd say dry vs humid air will cool the same going through the cooler. Density altitude will matter though (fewer molecules going through the cooler).
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
