Old 06-27-2010, 02:05 PM
prkaye prkaye is offline
Default current to charge battery
How much current is drawn from an alternator to charge the battery? I ran my engine today, and with only the Dynon EFIS/EMS and the fuel pump operating, my ammeter (which is positioned at the alternator output) was reading 13 amps. This seems quite high to me. My battery was a bit low because I had been configuring stuff in the EFIS, so I'm wondering how much current should be expected for charging the battery?
When I turned on my radios, pitot heat and all the lights, the ammeter was showing up to 50 amps... this seems really high for a vfr airplane!!
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 06-27-2010, 02:23 PM
AltonD's Avatar
AltonD AltonD is offline
The alternator field itself draws 5-6 amps. Strobes draw quite a lot of juice.
I have an IFR stack and with everything turned on, I am drawing 54 amps. I think you are ballpark.
I also know that with the B/U B&C alternator, I can get within the 20 amp limit by turning off strobes and one landing light (primary alt field off).
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 06-27-2010, 03:02 PM
Mel's Avatar
Mel Mel is offline
Current drawn from the alternator is dependent on quite a few things. If the battery is low, it will draw considerable current until fully charged. Incandescent bulbs draw quite a bit. Pitot heat will draw a lot.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-27-2010, 03:30 PM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
As a wild guess, up to whatever the Alternator will produce
Having drained the battery as you did, and just got the engine going, I saw 50A+ (with no other signifcant loads) for a short while with a 60A PP Altn.
Also a good point to make to those who use, say, a 20A fuse on a 40A Alternator, stating their max load is <20A. But the battery...
Andy
Old 06-27-2010, 07:33 PM
elippse elippse is offline
You are showing the total load on the alternator, not the battery charging current. A much better location for your ammeter is in the line from the battery to the buss, with the alternator connected to the buss. That way you will read charge current, from the alternator to the battery from the buss, or discharge current from the battery to the load on the buss when the alternator is off or not supplying all of the load. The slower your engine is running, the higher will be the field current to the alternator. Keep in mind the total load is the field, the master relay coil, and any load on this buss which is on.
