Old 06-24-2010, 11:03 PM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Default how to remove stuck quick oil drain valve?
The valve is aluminum, with 7/8" wrench flats, but the bottom moveable portion of the valve is much larger (and apparently unremovable) so you cannot get a box end wrench on it, or a socket, or even a flare wrench.
So far, open end wrenches just seem to round it off.
Any ideas? I was thinking heat gun, then pipe wrench.
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 06-25-2010, 05:48 AM
lancef53 lancef53 is offline
Since the valve is already bad, could you just cut the bottom off below the threads? Some heat and a six point socket should do the trick if you can remove the bottom of it. A good heat gun or careful heat with a torch will help.
RV-8 108LF
