Old 06-22-2010, 03:43 PM
prkaye prkaye is offline
Default oil dipstick calibration
My oil dipstick came with no markings on it. I was told by Aerosport that this is the way they come - they are supposed to be manually calibrated by adding oil 2 quarts at a time and marking the dipstick each time.
Unfortunately I've already added full oil to the engine, so I'll have to wait for my first oil change to do the lower markings.
Question - how on earth do I mark the dipstick? On production airplanes I've seen the dipsticks with the tiny markings engraved on the stick... I don't have the equipment to do that sort of engraving...
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 06-22-2010, 03:56 PM
yakdriver yakdriver is offline
Just use a file for the marks. If you have a dental lab near you they could engrave the numbers with a bur. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 06-22-2010, 04:40 PM
asav8tor asav8tor is offline
http://www.harborfreight.com/36-piec...g-set-800.html
plus this item
http://www.harborfreight.com/16-oz-b...mer-39616.html
Old 06-22-2010, 04:58 PM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
Default Marking Dip Stick
I used my tubing cutter to mark 4, 6, and 8 qt lines.
I just very lightly scored the stick. Simple and Low Cost
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2020 donation current
Old 06-22-2010, 07:07 PM
aerhed aerhed is offline
Tubing cutter... Brilliant!
Old 06-22-2010, 10:54 PM
I agree Jeff, that is brilliant. Don
Next project?
Old 06-23-2010, 09:16 AM
walter's Avatar
walter walter is offline
Stamped numbers are easier to read than a score mark.
Walter Tondu
Flying RV-8A - Fastback, IO-390, G3X Touch, 74 HRT
Prior RV-7A Build Log
Old 06-23-2010, 09:29 AM
In a 4 cyl lyc you only need 4 marks (2,4,6 & 8). Pretty easy even without numbers, but if anyone knows how to mark a nice numeral on a round stick without whacking the **** out of your stamp, let me know. I've tried engravers, but I can't do it. I Just scrawl.
Old 06-23-2010, 09:33 AM
fl-mike's Avatar
fl-mike fl-mike is offline
I filed a flat into the rod at each level and then stamped the number in the flat. Works well because the oil hangs in the flat and new oil is hard to see.
However...I didn't factor in the oil that is trapped in the filter when I did the fill-and-mark routine, so my marks are all a bit high.
Mike W
Venice, FL
N164WM
Old 06-23-2010, 09:38 AM
Bill Wightman's Avatar
Bill Wightman Bill Wightman is offline
Default Oil in filter included?
Does the number on the stick include any oil that might be trapped elsewhere in the system (like in the filter, etc)? I'd assume it does.... (?) Or should it only indicate what's actually in the sump?
This dipstick needs to know, since its time to mark mine.
?The important thing in aeroplanes is that they shall be speedy.?
- Baron Manfred von Richthofen
RV8 under construction
RV4 - Sold
United B777 FO, Chicago
Aero Engineer
RV8
