Old 06-21-2010, 05:20 PM
prkaye prkaye is offline
Default Pressurizing fuel system
On the weekend I'm goign to be adding fuel, doing a fuel-flow test and first engine run. After I pour some gas in the tanks, I read or heard somewhere that I can force fuel into the rest of the system before turning on the fuel pump by blowing through a tube connected to the fuel vent line. I wonder about whether the moisture this could introduce to the system would be bad. Is this necessary, or can I just pour fuel in the tanks and flip on the fuel pump to start pushing fuel through the system?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 06-21-2010, 05:40 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Just get it flowing with the fuel pump - if that doesn't work, you'll definitely have a problem you'll want to solve before flying!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
