There WILL be differences airplane to airplane due to weight and building tolerances. You need to make you own measurements.
BTW, there is nothing sacred as to the datum. That's your choice. 70" is just a suggestion from Van's. Some people seem to have trouble working with negative numbers. Personally I use the leading edge of the wing for the datum.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
