Old 06-21-2010, 12:21 PM
kentb's Avatar
kentb kentb is offline
Default SkyChart enhancements.
I am enjoying my iPad and SkyChartPro, but now have a couple of feature / enhancements to request.
1. I would like a way to find the airport by spelling it. I may not know the identifier or be able to find it on the map. Maybe hit 'direct' and then type in the name. The software could give me a list of closes matches.
2. I would would like to see Zulu time displayed on the bottom along with the trk dtk ...
3. I would like the METAR displayed in plan language.
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 06-21-2010, 12:29 PM
JDanno JDanno is offline
Default SkyCharts instructions?
Is there a place that actually has instructions on using Sky Charts? I'm having trouble figuring out how to do a couple of things. Especially how to get the little airplane symbol to start moving. It's stuck in SoCal and I can't get it to reset someplace else. Thanks!
PS, the charts look terrific on the IPad!
Old 06-21-2010, 01:03 PM
kentb's Avatar
Default Hi, Dan
The small icon in the lower left corner locks the plane to center of screen.
After that it will track and stay in the center. If you do anything with the map (zoom, pan) the plane will unlock and you will need to hit the lock icon again.
When you first start the app is ask if you want to view the documentation. There is a lot of information there, but you need to find it.
A little different then I am used to, no quite like my PC at work.
Kent
Kent Byerley
Canby, Or
Old 06-21-2010, 01:06 PM
flyboy1963's Avatar
Default plane language
...why the heck are METARS in code anymore ANYWHERE???
Pretty sure it doesn't save teletype ink either.....
R IS IT JST ME RNTNG&CMPLNING++?
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 06-21-2010, 02:36 PM
glider's Avatar
glider glider is offline
Try the FAQ first:
http://www.skycharts.net/forum/viewtopic.php?f=5&t=188
And also try browsing http://www.skycharts.net for information.
However, if the plane doesn't move when YOU move, then something sounds odd. First off - do you have an iPhone or an iPad ?
If an iPad - is it the 3G version ?
If its not the 3G version you don't HAVE a gps.
If you do have an iPhone 3G/3GS OR the 3G iPad it should work - the iPhone sometimes takes a lot longer to find your location (and it helps if you are in coverage). The iPad 3G should 'find' you quickly.
/ Heikki
Old 06-21-2010, 02:40 PM
glider's Avatar
Thanks Kent
I'll add those to the (already too long) to-do list.
Zulu time on display will most likely only be added in the iPad.
Regarding decoding - on the iPhone it will not be decoded due to the small display, that's what the color coded/sky condition rings are for.
On the iPad however, I may want to look into decoding the data.
But hey, we're pilots, I thought we liked reading very condensed information ?
/ Heikki
Old 06-21-2010, 02:49 PM
glider's Avatar
On the iPhone it made perfect sense to avoid printing long sentences on a tiny display when a condensed version is already available. It does decode into colors&sky conditions though. I'll look into adding a decoder at some point.
/ Heikki
Old 06-21-2010, 03:49 PM
DCat22's Avatar
DCat22 DCat22 is offline
I would still want a coded option, in any case. Once you learn a shorthand code of any sort well (or at least for me) I can read and assimilate it faster than longhand/wordy presentation.
Not saying you shouldn't have it spelled out -- just keep an option to have it both ways.
-Rick Greer, VAF #2492
Old 06-22-2010, 09:14 AM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
Heikki,
What's the status of XM WX for Skycharts?
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
Old 06-22-2010, 10:02 AM
glider's Avatar
Working on it. But also working on something else with higher priority.
Originally Posted by sprucemoose View Post
Heikki,
/ Heikki
