Old 06-21-2010, 05:17 AM
m3tt5 m3tt5 is offline
Default What about Avia CS prop?
Does anybody have a Avia CS prop on a 160hp? Are they worth it? Do they shorten your take of roll that much? How much do they cost and where do you get one?
Old 06-21-2010, 07:45 AM
mrreddick mrreddick is offline
Super Moderator
Location: Hangar/home at Hicks Airfield (T67), Fort Worth, TX
Default Avia Prop
You need to contact Russ Davies in Lubbock, TX. Russ, ya out there?
He had a 6A back in 2003 that had the Avia prop on it. I flew it one time while I was shopping for an RV and it was pretty impressive.
The TBO was a lot shorter, I think, than a Hartzell.
Mike Reddick
VAF#153
Pilots N Paws Pilot
RV6A N167CW 1,900 HRS
Ft Worth, TX (T67)
Old 06-21-2010, 05:27 PM
Ok thanks maybe he will chime in here. But it looks like it is not a very popular prop.
Old 06-23-2010, 02:47 PM
dav1111 dav1111 is offline
Super Moderator
Default RV with AVIA Prop
I bought an RV-6A (150Hp) which had a wood prop. Because of the inability to install a CS Prop on the O-320 Engine I decided on an AVIA Veriable Pitch Prop. I bought it direct from the factory and had it delivered fully assembled. The costs with shipping was about $6600.00.
If you want more information on the propyou might want to look at the AVIA web site:
http://www.aviapropeller.com
The specific prop I bought is located at:
http://www.aviapropeller.com/v503ap.htm
Don't be surprised if you have trouble understanding a lot about the AVIA prop from their web site, it is written by engineers, not pilots. The AVIA prop has been a long time staple item on some of the Zlin production airplanes.
I had no problems whatsoever with the Avia prop once it was installed and I went through multiple flights to get the best ground adjustment that I wanted. The performace with the wood fixed pitch prop was as follows: Takeoff 2200 feet; Landings 1200-1500 feet (hard to slow down with the fixed pitch prop); climb 500-600 fpm.
Performace after change over to the Avia Prop at sea leval: Takeoff 500-600 feet; Landing - 500-800 feet; climb 1300-1600 fpm depending on weight.
The following web sites might give you a little more insight into the Avia Prop which is factory installed on the Zlin Z-526 airplane:
http://www.airshowunlimited.com/arti...ldairnews.html
http://www.todayspilot.co.uk/flight_...jan03/2p1.html
If you don't have the option to install a CS prop because of the engine crankshaft being solid the AVIA is a great alternative. The best thing about the AVIA prop is when doing loops you never have to touch the throttle. As soon as you come over the top the prop changes and acts as a speed break when coming out and as you roll into the next climb it automatically changes to climb setting. It is hard to believe until you fly behind it.
From take off in the default climb setting to cruise is also automatic. As soon as you pull the nose down for near level flight the prop spinner which has air vanes mounted on it reverses direction and forces a valve in the hub to push oil into another chamber that changes the pitch to cruise. As soon as you retract power and start your approach to landing it again goes into the default climb pitch acting like an air brake, allowing real short field landings.
Russ Daves
Lubbock, TX
Proud to be a Veteran
N710RV - RV-10 Sold
N65RV - RV-6A Sold
N686RV - RV-6A Re-Built, Sold
N742PZ - RV-8 Co-Builder Sold
N-867RV -RV-7 Finish Kit
Old 06-30-2010, 10:11 PM
Default Prop
Thanks Russ for the info. Is their a chance I could talk to you on the phone about it.
