View Poll Results: How did you fasten your cowling?
Per the plans (Hinges) 38 44.71%
Quick-Turn fasteners such as Camlocs 27 31.76%
Screws / Nutplates 4 4.71%
Hybrid hinges and screws 19 22.35%
Pro Seal - just kidding' 1 1.18%
Multiple Choice Poll. Voters: 85. You may not vote on this poll
Old 06-20-2010, 08:39 AM
panhandler1956's Avatar
Default How does your cowl fasten?
So how did you fasten your cowl? Pros and Cons?
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
Old 06-20-2010, 08:46 AM
twsurveyor's Avatar
twsurveyor twsurveyor is offline
Originally Posted by panhandler1956 View Post
So how did you fastener your cowl? Pros and Cons?
I did mine as per the instructions (Van's Method), It has served me well for 530 hours. I love the clean look the hidden hinges give. Wouldn't have it any other way!
Tommy Walker
Ridgetop, TN (1M5)
RV-6A, N 350 TW
830 Hrs & "Climbing?!
Old 06-20-2010, 09:11 AM
flyboy1963's Avatar
Default hinges
Hate the hinges. Can't get a good look at things for a preflight. Have avoided pulling plugs, cleaning air filter, fixing things in general because its such a P.I.T.A.....especially lower cowl, that takes 3 people to re-attach.
Previous plane had a solid nose bowl, typical hinged sides, like a piper, where you could get at everything in seconds. Looked just as clean when closed if it fits well.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 06-20-2010, 09:22 AM
RV6_flyer's Avatar
After 2,380 flying hours, I have to say that the hinges have worked very well. They are light, cheap, reliable, very low drag, less work to install, easy to use when installed correctly, and hold up very well over the past almost 13-years of flying.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 06-20-2010, 10:58 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Hinges all around on my RV-8, with 1138 hours. Louise's RV-6 has hinges on the firewall, screws along the sides and on the bottom. I can generally pull my cowl quicker than she can pull hers. I love the clean looks of the hinges.
On the -3 we're building, since it has cheek cowls that interrupt the lines of the firewall, I am planning on using Camlocs along the firewall, and hinges on the sides (top to bottom cowl joint). At least I am planning it that way for now.....
I haven't had a cowling that I could open to inspect the engine for a preflight since...well, I haven't owned one that I could do that with in 30 years of airplane ownership. I generally pull the top cowl about once a month for some reason or other - of course, I do about five or six oil changes a year with my flight rate.....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 06-20-2010, 11:15 AM
apkp777's Avatar
apkp777 apkp777 is offline
I did hinges. However I am have a bit of trouble getting the top (long) firewall pin in. Otherwise, I can cowl and decowl in a minute or two. The nose fasteners are a bit of a pain. I may do something different there (camlocs?)
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 06-20-2010, 11:22 AM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Both
I used Skybolt 1/4turn fasteners around the firewall, and hinges along the sides.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 06-20-2010, 02:00 PM
DakotaHawk's Avatar
Default Mil-Spec fasteners
I used the Mil-Specs all the way around. It takes me about 5 minutes to remove my entire cowl (maybe a little longer than the standard hinges), but I find it easy and clean.
Scott "Grumpy" Stewart
#866 on the Van's RV-7 hobbs
#6563 on Van's generic hobbs
Arlington, WA
Old 06-20-2010, 02:58 PM
rleffler's Avatar
rleffler rleffler is offline
If you decide to stick with the hinges, start bugging Geoff for RV8 cowl pin covers.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 06-20-2010, 03:28 PM
Default Good idea
Bob,
Good idea!
Yeah I'm leaning towards hinges so I'll give him a shout...
Brent
Brent Owens
Columbus, OH
N784DE S/N #82614
