06-19-2010, 12:19 PM
Tip-up Leading Edge Gap
Hey - I am at everyon's favorite part of the build, working on the canopy.
I've spent the last week or so working on the frame and have it mounted on the fuselage and the holes in the hinges drilled.
I the gaps are fairly consistent and measure around 0.45" at the middle of the frame. However, I can not lift the frame with the skin on as it hangs up.
I know I need to widen the gap a bit, but was hoping to get an idea as to what others final gaps ended up at.
Jason
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Paid for 2020
06-19-2010, 12:45 PM
What a lot of folks do is put a shim between the skin and the frame along the leading edge to help lift it over the forward skin. I, of course, forgot to do that when riveting mine. But I also didn't drill the holes in the ears that well so the frame was already sitting somewhat higher than the forward skin. Nonetheless, I still have a gap that's about like yours. I may end up making it even more.
06-19-2010, 12:51 PM
You cannot finalize this gap properly until the forward skin is riveted. Clecoes just don't do the job here. After the forward skin is riveted, you can file the leading edge of the canopy skin for final fit.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
06-19-2010, 01:12 PM
So..... is the best course of action to leave it as is (non-opening) and just wait to file it once the forward skin is riveted?
Jason Tremble
Paid for 2020
06-19-2010, 02:36 PM
What I did was put a couple layers of duck tape over that area letting the canopy sit down on it while building.
This stopped it from catching till I could do the final filing....
06-19-2010, 03:54 PM
You will have to rivet it AND install the gas struts to see the final gap. The struts will noticeably push the canopy forward when in the closed position and likely cause the skins to catch on each other (and bend) when subsequently opening the canopy.
Fin
9A
06-19-2010, 11:33 PM
shims
I'm doing my canopy now also, and had the same problem, also with about a 0.045 gap. I put 3 shims inbetween the skin and frame and it opens fine. But also, my skins are not riveted and I expect this whole thing to move more as I finish the canopy. You can see it at
http://www.mykitlog.com/users/displa...=105375&row=15
I have not yet enlarged the 1/4 holes to 3/8 for the bushing. I'll do that last. I'm thinking if after the canopy is done I can move those holes slightly when I put in the bushings.
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
06-20-2010, 07:56 AM
I used this builder's method to keep the canopy from getting pulled too far forward.
