Old 06-16-2010, 09:01 PM
danielhv's Avatar
danielhv danielhv is offline
Default How do you identify washers?
I'm finishing up the wing kit, and I'm starting to attach the control surfaces to the wings, and hook up the bell cranks, etc. There are alot of washers used in various places, but Vans sends the washers all mixed up in a paper bag. So my question is: Is there any way to gain enough information from the part #'s on the plans to determine which washer is which?
Old 06-16-2010, 09:47 PM
Wayne Gillispie Wayne Gillispie is offline
Default Identifying various washers...
I look at the quantities and try sorting that way first. Then compare the washer inside hole diameters to their corresponding screw sizes...#4, #6, #8, #10 and so on. Washers fit somewhat loose. Mostly steel washers came in my kit. Stainless steel and aluminum are also common in our industry. Then you have thick or thin washers, thin denoted by "L" for light. Good luck.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 06-16-2010, 09:58 PM
GAHco's Avatar
GAHco GAHco is offline
Arrow The Basic Washers
Try this PDF for your basic normal washers http://www.gen-aircraft-hardware.com...df/nas1149.pdf
This will also help also for some of your custom applications on fairings and such
http://www.gen-aircraft-hardware.com...pecialwash.pdf
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 06-17-2010, 04:18 AM
airtractor8 airtractor8 is offline
Look in the aircraft spruce catalog under washers...they have a great decode!
Old 06-17-2010, 09:14 AM
yakdriver yakdriver is offline
Easiest thing to do with hardware (nuts, bolts, rivets etc) is to take all of it out of all the bags and organize it in plastic trays. That way when the plan calls out for say an AN3-10 bolt you just go to the tray and grab it instead of searching through all the bags. After building a Lancair and a Glasstar this is one area that Vans dropped the ball. There is no rhyme or reason to their inventory or part numbers. Made it really hard to locate stuff at times. As for washers, you will figure out what the sizes are. Also order a bunch of extra -3 and -4 thick and thin washers. They really come in handy and they are really cheap. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 06-17-2010, 11:10 AM
Vern's Avatar
Vern Vern is offline
Default Identifying parts suggestion/ getting organized
For shops (with helpers especially), it is handy to make up a poster or wall board with 1 sample of common items glued on with a dab of clear silicone. That way helpers have a starting point when sent to fetch. You can order 1 each from Spruce and even use their bag labels on your poster.
Gun store used to have similar displays for ammo.
A cheap bolt gauge is handy also.
Keep used bolts and screws separated from final assembly items.
I always like to keep a cup handy for stuff found on the floor. Periodically sort and 'return to stock.'
Zip lock plastic bags are great. Felt tip pens will label them. For things like control nuts,bolts, washers, there are small clothe bags with tie strings. You can pull a control or engine part off, put all the fasteners from that location in the tobacco bag, and tie it onto the part.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 06-17-2010, 04:47 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Put the special Vans washers...
..to one side though.
They are unique to Vans and have part numbers like 5072-xx-yyy
I know of three. One is a 3/16 ID washer with a very small OD of about 1/4 inch.
Two are AN3 and AN4 washers, but in a size in between an AN960 and an AN970...
There may be more...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
