mounted in the main fuel line between the boost pump and firewall. The only difference is that I match drilled the belly skin using the holes in the transducer as guides and dimpled the holes. I put countersunk screws with the heads down, up through the belly, through the transducer and put nuts on top to secure it. Probably WAY overkill but it looked to me like it wanted to be securely fastened to something.
Jeremy Constant
RV7A 52 hours and chasing high-ish oil temps
