Go Back   VAF Forums > Regional Forums > Southeast
Old 06-15-2010, 07:37 AM
noelf noelf is offline
Default 08-28/29-2010: (NC) Apex:EAA 1114 Hosting EAA SportAir Workshop at Cox Field
August 28-29, 2010, EAA Chapter 1114 (Apex, N.C.) is hosting the EAA SportAir Workshop "Discover Aircraft Building" at Cox Field (NC81). This workshop is the ideal starting point for new or potential RV builders. The cost is $195 / person for two full days of hand's-on learning.
For details, see www.sportair.com . Seating is limited, so sign up ASAP.
Directions to Cox Field may be found at www.eaa1114.org
Cox field (NC81) is located under the outer ring of the Raleigh, NC (KRDU) Class C airspace.
Old 07-09-2010, 02:43 PM
Default bump to top
bump to top...
