Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 06-14-2010, 08:13 PM
rvdave rvdave is offline
Default paint chips in propellor
I have a Sensenich prop on my rv6, noticing paint chips on rear of blades, not into the metal, wondering whether to sand out chips to bare metal or fill with something before repriming and painting?
Dave Ford
RV6 in Cadillac, MI
Old 06-14-2010, 11:08 PM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
Default Nothing
Hi Dave,
I see you got no replies on this so I?ll put in my two cents. My airplane is a flyer, 200 hours a year, as such the prop has nicks on it like you describe, I don?t feel qualified to paint a prop, I can?t balance it and I can?t insure each blade gets the same paint, so as a flyer, not a hanger queen my prop lives with nicks and paint erosion between overhauls, it?s just the life of a prop that?s in use. Mine is an MT that has a 72 month or 1800 hour TBO, it has 4 years in and 840 hours, by all indications it will make it to its 72 months then the shop will make it like new again.
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 06-15-2010, 10:29 AM
664781 664781 is offline
Lightly sand and touch up paint. Don't go down to bare metal unles you have to remove high metal.
Kurt Lohmueller A&P, DAR
Powder Springs, Ga
RV6A "Kurt's Toy" - Flying
RV12 - Flying - Sold
Old 06-15-2010, 01:33 PM
I agree with lightly sanding the spot/spots and touching them up, this is perfectly acceptable to do between overhauls.
Russ McCutcheon
Old 06-15-2010, 05:56 PM
The chips I describe are crater-like so I'm thinking if I lightly sand the edges of the craters I will have "dips" or craters with rounded edges. Should I lightly fill with a sandable primer to make a smooth surface?
Dave
Old 06-15-2010, 07:40 PM
The touch up paint will fill the crater.
Russ McCutcheon
