There is no real difference between the engine's. 320's don't have solid and hollow crankshafts, only hollow. I can't remember for sure, but the only real difference between them would likely be the prop mounting dowels and maybe the accessory housing having the capability to mount a governor drive on one and not the other. Anyway, the mag choice between them wouldn't logically be any different. The difference in the lag angle is minor and the difference in starting capability of the engine using either isn't noticeable to me. Many will say that if you time a mag at 25 you should use the 25 lag mag, but honestly I have never seen a difference in starting, using either mag on engines times to 25 BTDC. I think the likely reason that they have two different mags listed for the same basic engine is what was available when the engines were certified in an OEM application.
I think you will be fine using either mag. If you are a certified installation, you should use what Lycoming prints in the bulletin.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
