Old 06-14-2010, 07:51 AM
129TG 129TG is offline
Default Using Silka on fiberglass fairings
I purchased the slider and windscreen fairings from Britta and wanted to ask if anybody has silkaflexed them onto their canopy and windscreen. I will be silkaflexing my canopy and windscreen soon and wondered if someone had gone there before me. I asked Britta if they knew anyone that had fitted their fairings using this method and they were unaware of anyone using this method. From what I have read bonding to fiberglass is not a problem and it seems doable to me. Pros/Cons?
Thom Grant
KDTS - Destin, FL
Old 06-14-2010, 10:23 AM
Lars Lars is offline
I laid up my own one-piece fiberglass canopy skirt, which I eventually bonded to my canopy assembly with Sika. However I also used pulled rivets along the sides into the steel canopy frame, per the plans. I followed Sika's recipe for preparing the surface, using the cleaner and primer. As with everything else I've bonded with Sikaflex, the bond appears to be tenacious. Not flying yet, so take the advice with the usual disclaimers.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
Old 06-14-2010, 04:37 PM
dav1111 dav1111 is offline
Super Moderator
Default Sikaflexing canopy and fairings
My partner and I used Sikaflex to install the canopy and the canopy fairings. Drilled a few holes in both the canopy and fairings to hold them in place with clecos while the Sikaflex setup.
Russ Daves
Lubbock, TX
Proud to be a Veteran
N710RV - RV-10 Sold
N65RV - RV-6A Sold
N686RV - RV-6A Re-Built, Sold
N742PZ - RV-8 Co-Builder Sold
N-867RV -RV-7 Finish Kit
