Old 06-13-2010, 12:36 PM
Flying Scotsman Flying Scotsman is offline
Default Crankcase breather tube
Received the tube fF-705 and the hose (NAPA) 9816 from Van's, but hmmmmm....that won't fit this engine that I can tell (Lyc IO-360-M1B). The breather fitting comes out of the engine nearly horizontal, pointed aft and for the life of me I can't see that this will work with the parts I have.
Suggestions? Is there a different fitting that points up (as per OP-27)? Or do people use something different here (I'm also planning on putting an Andair air-oil separater in)?
TIA!
Steve
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 06-13-2010, 12:53 PM
AirbusPilot AirbusPilot is offline
Hi,
I installed mine on my 8 with a IO-360-M1B but I have to make a lot of diferent bend, not even close to vans instruction. check my pictures at picasa
Fernando Abasolo
Santiago Chile
SubSonex waiting for tailkit to arrive
Flying phase II RV-8 (SCSE) Serial Number 83290, Tail Number CC-AJC
Flying RV-8 (SCTB) Phase II 600 hours and counting since February 22nd 2010
Serial Number 82727, Tail Number CC-PXG
Lyc. IO-360, Hartzell Prop
VAF #2056
EAA Member 774981
Old 06-13-2010, 01:06 PM
shuttle's Avatar
shuttle shuttle is offline
Steve
I have an -M1B on a -7. Here's a photo of my Andair separator install.
The -M1B breather is pointing in pretty much the right direction for the separator in this FW location..
I'm not sure yet what I will do with the FF-705 tube but I figure I will be able to use some of it.
I have also bought some MIL DTL 6000 Soft Flexible Hose to replace the Van's supplied hose.
Hope that is of some help.
p.s. a common position I have seen for the separator is top centre of the FW. My engine (a Mattituck) has a 90 degree oil filter adapter. If I had put the separator FW top centre then I would have had oil breather hose basically wrapped around the oil filter which I though would have made future filter changes more cumbersome. My chosen location gives a much straighter hose run from the engine breather fitting to the separator.
Steve Hutt
West Sussex, UK
RV-7 G-HUTY (not flying yet)
( Tip-UP / TMX-IO-360-M1B / Hartzell 7497-2 / 1x LSE PLASMA III / Dual AF4500's / AF-Pilot AP / 695 )
