Old 06-13-2010, 07:14 AM
macrafic's Avatar
macrafic macrafic is offline
Default Alodine Won't Take
I had previously painted my interior with self-etching NAPA primer and primer sealer. To mount my antenna, I cleared a small area using Acetone so that the base doubler for the antenna would have a good ground connection to the aircraft. Then used a degreaser and water rinse (same procedure I've used for bare aluminum parts).
However, when I tried to alodine that small area, to provide long-term corrosion protection, the alodine would not take. I think it could have something to do with the "self-etching" components of the primer I used.
Has anybody else run into this problem? Any ideas for solutions?
Rich and Cindy Macrafic
Rochester, MN
Flying
Old 06-13-2010, 07:17 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Did you acid etch before the alodine??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 06-13-2010, 07:48 AM
apkp777's Avatar
apkp777 apkp777 is offline
What do you mean by "the alodine would not take"? If you mean it didn't dye the metal yellow, or it "beaded up", you can scuff with blue scotch bright and clean with MEK and it should work pretty well. However, if the alodine doesn't "take", I'd say neither would corrosion. Paint on.
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 06-13-2010, 11:45 PM
Flying Scotsman Flying Scotsman is offline
How old is the alodine? Has it been hit with UV for an extended period?
I had an older quart bottle of the stuff that was a few years old, and it, too, wouldn't "take" (just left the metal a very faint yellowish color). It had either expired, or been UV light-struck, or something, because I bought a new gallon bottle of the ****, and it worked virtually instantaneously on all parts. Now I have to figure out how to dispose of the old bottle (toxic waste).
If it's an older bottle of alodine, get some new stuff and I'll bet it works.
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 06-14-2010, 11:30 AM
macrafic's Avatar
Mike, I didn't acid-etch before alodining. Nor have I previously, without any issues.
By "not taking", I mean it doesn't yellow or golden; just remains shiny aluminum.
Alodine is good, since I just finished alodining the mounts for my antenna.
I will try scuffing with scotchbrite (which I had done before priming), cleaning and trying again. Hopefully the scotchbrite will clean out whatever is preventing the Alodine from doing its job.
apkp777, I wondered the same thing. If the aloding doesn't "take", maybe corrosion wouldn't either.
Rochester, MN
Flying
