06-12-2010, 08:41 AM
Setting alternator belt tension
What is the correct way to set the tension of an alternator belt?
06-12-2010, 08:51 AM
I was taught that you want 1/4" deflection max and minimum.
Tony Phillips
N524AP, RV 9 (tail wheel)
06-12-2010, 09:26 AM
Here's a post I made in 2006 that should help:
"Belt deflection is an unreliable method of tightening the belt.
Instead, use a torque wrench on the pulley belt and adjust the tension so that you get about 12 ft-lbs before the belt slips.
A loose belt can lead to under-voltage or over-voltage from the alternator. Overvoltage is caused by the regulator trying to force more output from the alternator while the belt is slipping. When the belt grabs, it puts a surge of voltage on the bus.
Please don't ask me how I found out!
ref Lycoming s. i. 1129A
Lycoming SI 1129A Accessory Drive Belt Tension
New 3/8? 11-13 ft/lbs 132-156 in/lbs used 3/8? 7-9 ft/lbs 84-108 in/lbs
New ?? 13-15 ft/lbs 156-180 in/lbs used ?? 9-11 ft/lbs 108-132in/lbs
Vern Little 9A"
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
06-12-2010, 09:44 AM
Lycoming: Apply torque wrench to the alternator pulley nut and turn it in a clockwise direction. Observe the torque shown on the wrench the instant the pulley slips.
Belt width 3/8"....... NEW 11 to 13 ft-lbs. USED 7 to 9 ft-lbs.
06-12-2010, 10:07 AM
Sorry, belt deflection should only be used for Pilot pre-flight. Got my functions crossed.
Tony Phillips
07-01-2012, 01:54 PM
Anyone able to indicate where this is written by Lycoming?
CharlieWaffles - But you can call me " Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
09-02-2012, 11:15 PM
Just installed the prop for the last time (I hope, until time for servicing at 72 months), and now need to tighten the alternator belt. Bumping this to see if anyone has a pointer to the Lycoming SI-1129A on this (can't find it on the Lycoming site).
TIA!
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
09-03-2012, 05:11 AM
PlanePower says this...
Sam Evans
RV7-A O-360 C/S
VAF#812
09-03-2012, 09:29 AM
Yes... Lycoming SI 1129 - now up to "B" revision.
But not posted on their web site...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
09-03-2012, 01:27 PM
lycoming SI 1129B
If someone wants it I can e-mail it to them. Russ
Russell Brown
A&P/IA
"Happiness may never be sensibly pursued as an end in itself, because happiness is the by-product of achievement." -- Northcote Parkinson (paraphrase)
Wasilla, Alaska
