Only pre-2000 Honda 4-cylinder alternators have the correct cooling fans for Lycoming usage (the older Honda's run backwards compared to almost all other automotive engines). The one model that seems to fit the best is an '87 Civic unit, and that's a 60A. Get the Denso version; those cars also came with Hitachi alternators. The Honda alternators also typically use a 4-wire regulator. You can use it that way, or get a Toyota 3-wire version.
So the PP units are Denso, have a Honda rotor, not sure which castings (but the '87 Civic is close enough), and most likely use a modified Toyota regulator. If you're cheap like me, you can mod the regulator and brush holder yourself like
this story I wrote and 'Lectric Bob published. This way, the alternator cannot "run away" and you have complete control over it.
Heinrich Gerhardt
RV-6, flying
