Old 06-10-2010, 05:04 AM
Vlad Vlad is online now
Default Pneumatic connectors thread
I am not in the shop right now and would like to order some connectors for pitot-static system. The same ones Doug referred on home page http://www.automationdirect.com/adc/...ght_(Hex_Body)
Could somebody take a look at the thread at the back of altimeter and ASI? Is the thread NPT or other?
Old 06-10-2010, 05:34 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Standard pipe thread - NPT.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 06-10-2010, 05:36 AM
Paul thanks.
Old 06-10-2010, 05:41 AM
noelf noelf is offline
Default The most common size is...
...1/8 inch NPT
Old 06-10-2010, 05:49 AM
Tony Spicer Tony Spicer is offline
And for similiar fittings in smaller quantities, see this:
http://www.mcmaster.com/#catalog/116/166/=7gxkw8
Tony
Old 06-10-2010, 06:01 AM
Thank you guys. Tony an offtop Q for you - in your album image #89 you cut the exhaust pipes at an angle. Is it just for aesthetics or has an aerodynamic benefit?
Old 06-10-2010, 06:03 AM
Bill Wightman's Avatar
Bill Wightman Bill Wightman is offline
Hey Vlad! You might take a look at what Stein has. These fittings look really nice.
http://steinair.com/pitot.htm
?The important thing in aeroplanes is that they shall be speedy.?
- Baron Manfred von Richthofen
RV8 under construction
RV4 - Sold
United B777 FO, Chicago
Aero Engineer
RV8
Old 06-10-2010, 06:33 AM
The pipes are cut short, as I didn't want anything hanging in the airstream. Don't remember where I read it, may have been in Paser's book, but the 30 deg cut is supposed to deflect the exhaust flow down. The deflectors on the bottom of the cowl are there for the same reason, and to gain a bit more clearance.
http://picasaweb.google.com/tonyboyt...11928565613938
Tony
