Garmin 296
My 296 will intermittently show "Low External Voltage" when alternator off or on. Both cases voltage is fine and I am wondering if this is a sign that 296's internal battery is failing. The unit is about 6 years old. Anyone else have this symptom? Wiring and grounds check fine.
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
