Originally Posted by ronschreck
Mark,
All bets are off if you have more than enough horsepower at low RPM. If you are comparing your Rocket to RV's then we are talking apples and oranges.
(Were you the last guy in our 37-ship formation for some reason?)
PS: Whatcha flyin' these days?
Hey Ron:
I'm a CP on the Devil Dog B25, and still flying the Rocket. The Beech was bashed at an airshow by the prop blast from an AN2, so it's in the process if getting repaired. I'm looking forward to getting beck into the family Champ (my brother is not flying it, so it's coming back here) -- I used to fly that one when I was very young.
Nah, I'm not comparing anything other than RPM, as concerns aero braking. More turns = more braking ability, but in reality, it should not be necessary to use that much braking,, and it is quite possibly dangerous, but at minimum it is bad form. My point it that it's easy to inadvertently push your tailwheel into the windshield of the plane behind you when you have a bit too much RPM dialed in. Match leads' setting and things will go smoother and easier.
Yes, James an I had a discussion on that specific point, as his plane was not smooth at anything less than 2600, so I asked him to be extra careful with pulling the 'GO!' Knob backwards. For the most part, it worked out. Being #37 in a 37 ship formation is not the easy spot, that's for sure.
Then again, if this formation stuff was easy, everyone would be doing it!
Carry on!
Mark
