Old 06-09-2010, 02:15 AM
ron sterba ron sterba is offline
Wink MATCO Parking brake PVPV-D ( D-Dual)
Has anybody installed one of the new Matco parking brake units? Like to see your mod on it if I could please. Just received my unit new from SPRUCE. Trying to figure how to set it up. It needs a special bracket. I did get one picture of a mod ( Thanks) with a older model which feeds from the front of the unit. This one feeds from the top and then goes out to the brakes at the bottom. Thanks Ron in Oregon.
Old 06-09-2010, 03:44 AM
rleffler's Avatar
rleffler rleffler is offline
If you don't want to make you're own bracket, Dave Ward sells one intended for a RV-10, but will work with any RV. You can get it from Airward or from Vans. These are both kits, but you should be able to get just the bracket.
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 06-09-2010, 11:25 AM
Bob thanks for the info. I'll look into it. That website shows the first generation PVPV-1. This PVPV-D D for dual is the LATEST OUT AT $103 BUCKS FROM Matco.
Old 06-09-2010, 11:48 AM
Transporter Transporter is offline
Default Matco Parking Brake Valve
Ron,
I purchased the RV10 mount as described above; it came with instructions and holes for the PVPV-D style (as well as the older design).
I determined the best cable path first, then oriented the mount and valve. I routed the brake lines as part of this process using some coat hanger wire to see if the tubing runs would work.
No issues. No mods required to the mount or valve...
Good luck,
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
