Old 06-08-2010, 11:22 AM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default Crank sensor routing.
I have a tmx io2320 with the LIGHTSPEED ei on one side. The crank sensor pick up at the flywheel looks really flimsy. The little wire from the pick up is wax string tied to the sensor board and then just hangs, kind of kinking the wire and looking very susceptable to damage. With the baffles fitted and needing to run this wire back several feet, I have some questions.
Anyone have pics of how they supported, protected and routed this? Just the bit from flywheel crank sensor around baffles to side of engine is the issue. Scanned archives and build logs and lightspeed website and cant seem to find a good resolution. Thanks for any suggestons.
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 06-08-2010, 01:28 PM
MS19087's Avatar
MS19087 MS19087 is offline
Default Will try and get you pics
I have the exact same set-up (TMX IO-320 w/ Lightspeed). I will try and get pictures. I know I used lots of hi-temp RTV to secure it where it passes through the baffles - I think it will work fine (not flying yet!!)
Mark
RV-9A; Sold
RV-14A; Building
2020 =VAF= donor
Old 06-08-2010, 04:09 PM
Norman CYYJ Norman CYYJ is offline
Route the wire so that it runs under the baffles and along the case housing bolts held on with Adel clamps
