Is dry tappet clearance measured with the pushrod forcing the tappet to bottoming, or it at contact(tappet pushrod seat at contact) with no pressure?
My understanding was that it was with some pressure (against the tappet internal spring), then measured between at the valve stem and rocker contact point when the tappet internally bottoms out.
It doesn't make much sense to have clearance (lash) on the pushrod at just contact - the pushrod risks falling out of position. But I've been wrong for reasons I didn't fully understand before asking before!
H2AD if it matters, but I don't think it does - just a different hyd lifter.
If it's at contact, LOL, I'm going to need a LOT of shims. The case machining took ~.015" a side out.
I've seen the A&P consensus is that clearance shrinks as the engine breaks in - that the valve seating depth grows (and decreases clearance) more than any break-in of the pushrod/lifter/cam break-in.
Thanks, RIck 90432
PS: anybody have a clue how to TDC @1 a D3000 mag?
