Old 06-05-2010, 11:39 AM
AlexPeterson's Avatar
Default Question - what is the generic name for these:
Greetings,
I'm looking (for a non aircraft use) for fittings like these types we use on the fuel pump, and am wondering if there is a generally accepted name for them. Specifically, the machine thread/O-ring type of fitting (not pipe thread). This is for a hydraulic system application.
Thanks in advance!
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 06-05-2010, 12:01 PM
comfortcat's Avatar
comfortcat comfortcat is offline
Talking
Oops. Sorry they are only NPT on the other end. I'd still call them tho...
www.mcmaster-carr.com calls them flare tube fittings / adapters.
Flared Tube Fittings
132 products match your selections
Shape Adapter
Adapter Type
Male Pipe Adapter
Female Pipe Adapter
Banjo Adapter
Material
Originally Posted by AlexPeterson View Post
Greetings,
Thanks in advance!
David Boeshaar
RV-9A - N18TD (reserved) - Fuselage.
"My greatest fear: What if the hokey pokey really IS what its all about?"
TDAircraft.com
-July-
Old 06-05-2010, 01:14 PM
Default Found it!
Thanks for the try! I found it: ORB, for O-Ring Boss.
Alex Peterson
KADC, Wadena, MN
Old 06-05-2010, 09:38 PM
terrye terrye is offline
Default ORB fittings
All of the hydraulic hose/fittings companies such as Parker and Aeroquip Industrial Hydraulics lines will have these kind of fittings. They are indeed called ORB for O-Ring Boss and are defined by SAE standard J1926-1, -2 and -3. The ports and studs are straight thread UNF threads. The o-rings and o-ring recesses are also defined by the standard. There is also a metric version of these defined by ISO6149, but I doubt you're looking for these.
If you need to make the female port there are form tools available.
Parker's catalog 4300 has a good General Technical section for a wide variety of ports and end fittings including thread sizes. Unfortunately I was unable to get a link that worked.
Your local hydraulics dealer should be able to help with parts and catalogs.
Old 06-06-2010, 06:13 AM
DanH's Avatar
DanH DanH is offline
Different manufacturers use a variety of similar names to ident a bunch of not-so-similar items. I'd just be descriptive ("I want a straight SAE and 37 degree flare"), or I'd do my own catalog research and give him a part number.
Dan Horton
RV-8 SS
Barrett IO-390
