Old 06-04-2010, 06:24 PM
RobinHou RobinHou is offline
Default Elevator Horn Drill Bushing
The instructions call for 1/4 OD and 3/32 ID. The closest thing I can find in my local hardware store is 1/4 OD with .049 wall which makes the ID around .152 or a little smaller then 5/32.
Any suggestion?
Old 06-04-2010, 07:51 PM
Randy Hooper Randy Hooper is offline
Default Find a friend with a lathe
A 1/4" bolt can be made into a bushing pretty quick.
Randy Hooper
RV-8
N84H
Old 06-04-2010, 08:41 PM
mcencula mcencula is offline
Default I used thinwall brass tubing
...from a local hobby shop. They have a bunch of sizes and each one nests nicely in the next. Just cut off about 1" from each size, nested them together, and presto! instant drill bushing. The tubes cost about $1 to $2 each.
Mike Cencula
RV-7A (fuselage)
www.our7a.com
Betcha my pile-o-scrap is bigger than your pile-o-scrap.
Old 06-07-2010, 09:43 AM
trib trib is offline
Default Brake tubing
I used brake tubing from a local auto parts store ( I think it was Advance, but NAPA would be best if near you). There are many different sizes. Just take a caliper with you and start measuring. The tubing is about the right hardness so you don't have to worry about enlarging it with the bit. These worked in any application I had for a drill guide.
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build )
N621TR In unrestricted operation
Old 06-07-2010, 11:23 AM
bkthomps bkthomps is offline
can someone post the mcmaster carr part # that is relevant to this?
Old 06-07-2010, 11:47 AM
esjacoby77 esjacoby77 is offline
I think the bushing I ordered from McMaster-Carr was part# 8491A784. It has a 1/4" OD and inner diameter setup for a #40 drill. As others have found, it was slightly to big, so I had to chuck it into my drill press and reduce the OD until it would fit through the bearing.
Old 06-07-2010, 12:06 PM
Maxrate Maxrate is offline
Robin,
I Drilled a pilot hole using a bushing that I purchased from ACE. Vans calls for an inside diameter of 3/32 but the closest I could find was 7/64. After disassembly I was able to final drill it to 1/4 inch. I would highly recomend using a new sharp 1/4 inch bit for the final hole.
Good luck..
Mark Malone, RV7
Wings complete, SB 14 complied with, canopy and cowling in progress, Up on the gear.
N442MM reserved
http://www.mykitlog.com/MikeMike
2020 Donation gladly paid..
