Old 06-04-2010, 01:50 PM
philb philb is offline
Default Andair extension
Andair 12" extension for FS20X7T coming up as $130 thorough Andair site, does this seem about right? Seemed a bit steep for a $200 valve, but just wanted to make sure in the ballpark. Seems you can't use the faceplate that come with the original - need a new one?
Haven't checked through ACS, but would like to support the original manufacturer.
Already pushed the "easy" button for braided fluid lines, and it sounds like it's easier to fit everything in the tunnel with the valve down low, so am inclined to use it...
Phil
KSLC
Old 06-04-2010, 06:04 PM
turneraero turneraero is offline
Phil,
That sounds about right, when I got mine the exchange rate was a little higher. I also got a few extras (ujoint,etc) and so with shipping it was $193.
It is a very well made piece though and I had to have it.
Jerry
RV-9A
