Old 06-03-2010, 11:23 PM
ao.frog ao.frog is offline
Default More HP by insulating the induction tubes?
Hi.
I'm considering installing these: http://www.flyboyaccessories.com/sto...roducts_id=269
Does anyone have experience with them? Seems like a good idea...?
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
Old 06-04-2010, 08:04 AM
RV8RIVETER's Avatar
RV8RIVETER RV8RIVETER is offline
Smile Easily tested
I you want to try an experiement with it, seems it would be easy to gather data on your stock system first. Then try an aluminized wrap, much cheeper to buy some from a local race car parts supplier. Then compare your data to see what difference it made.
Like; http://www.pegasusautoracing.com/pro...p?Product=1828 or http://www.pegasusautoracing.com/pro....asp?RecID=395
With the airflow thru the area I doubt the intakes absorb any significant heat radiated by the exhaust pipes, with most of the heat transferred by direct contact with the oil. But hey, your experiment might prove otherwise.
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
Old 06-04-2010, 09:35 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
IIRC, Lyc claimed 2% hp from chrome tubes, heli stuff.
Chrome reflects the heat..............
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 06-04-2010, 10:39 AM
nucleus nucleus is offline
Default Kent Paser Did It
Just as a point of reference, Kent Paser of Speed with Economy fame insulated his intake tubes. Doesn't mean that it works of course. He states on page 56 of his book that insulating the tubes allowed him to run 50-75 degrees leaner before the engine got rough.
I think that insulating the exhaust makes a lot of sense, mine are jet hot coated inside and out, which reduces radiant heat from the exhaust 50+%. The increased heat held within the exhaust is supposed to increase power due to better scavenging, about 1.5% or so. The downside is that once you have the exhaust coated, it can no longer be welded. You could do the same coating on the intake tubes as well.
Hans
Dr. Hans Conser
Bozeman Chiropractor
RV-6A 195 Hours, up for sale soon?
Old 06-05-2010, 08:48 AM
vfrazier's Avatar
vfrazier vfrazier is offline
Being the guy who peddles these things, here's my experience:
1)I initially installed these to keep the exhaust heat from damaging the rubber intake hoses. The heat reflected away from the rubber parts absolutely works as intended here. The intake hoses were being roasted on my plane beforehand. They were replaced then I installed the heat shielding, and the intake hoses still look great several years later.
2) My injectors were balanced (GAMIfied per Don Rivera's instructions) before the heat shielding. After installing the heat shielding, the injector balance changed and had to be redone. I interpret that as possible heat rejection.
As stated in the product description on the web store, my opinion is that 1400F exhaust heat trumps 200F oil heat when it comes to which one affects the induction air temps the most. I don't see much chance of "cooling" the induction air by leaving the intake tubes bare... not with up to 350F air blowing past them on all sides, and 1400F exhaust pipes an inch away.
Obviously all of this is quite subjective. YMMV.
I am pleased with these items on my airplane and have no intention of removing them. They seem to do what I intended.
I would like to clarify one thing though, if we were motivated to "move dollars out " of our customers pockets we'd find a different business, one where we didn't have to worry about offending hundreds of RVers whom we consider to be our friends. We're not in this for the money. Mostly our tiny little business started by chance, grew by luck, and has absolutely no chance of ever threatening Aircraft Spruce, Wicks, Vans, etc.... We like it that way.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 06-05-2010, 11:00 AM
szicree szicree is offline
Wouldn't it be relatively easy to stick a temp probe in the intake tube and get objective data?
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 06-05-2010, 11:23 AM
RV7AV8R's Avatar
RV7AV8R RV7AV8R is offline
I put some heat insulating tape from ACS on my intake tubes in order to try to balance the EGTs with my Carb set up. It did help a little, but I can no longer remember the exact differences that I saw. If I recall correctly, it changed hotest to lowest sequence. It didn't occur to me there may be improved HP, this would be much harder to measure.
John Adams
Seattle
RV7 600+hrs
Paid 12/2014
Old 06-06-2010, 06:03 AM
G3i Ignition's Avatar
G3i Ignition G3i Ignition is offline
Default Induction Tube Temp.
I did this test last summer. On a IO-540 @ 2500 RPM, 178 degrees oil temp, ambient air temp 76 degrees, temp probe in the induction tube located 4.00? before the intake valve. The temperature rise in the induction tube was less than a 1-1/2 degrees (actual reading was fluctuating between .7 and 1.3). I have also been doing R&D on induction & exhaust system mods. With and average of 4+ mph speed increased @ WOT on a RV4. Soon G3i?s aircraft engine dyno facility will be operational for a more controlled and accurate data information on performance mods. claims.
Thomas S.
www.g3ignition.com
See you there, KOSH. Booth #1148
Old 06-06-2010, 08:31 AM
RV7AV8R's Avatar
Originally Posted by G3i Ignition View Post
I did this test last summer. On a IO-540 @ 2500 RPM, 178 degrees oil temp, ambient air temp 76 degrees, temp probe in the induction tube located 4.00” before the intake valve. The temperature rise in the induction tube was less than a 1-1/2 degrees (actual reading was fluctuating between .7 and 1.3). I have also been doing R&D on induction & exhaust system mods. With and average of 4+ mph speed increased @ WOT on a RV4. Soon G3i’s aircraft engine dyno facility will be operational for a more controlled and accurate data information on performance mods. claims.
Thomas S.
www.g3ignition.com
Tom, What temps were you seeing in the induction tubes with an ambient of 76 degrees? Also, cyl #3 & #4 have a hot exhaust pipe on either side of the intake tube so I would guess they would be more effected by the heat than cyl #1 &#2.
John Adams
Seattle
RV7 600+hrs
Paid 12/2014
Old 06-06-2010, 10:48 AM
Originally Posted by RV7AV8R View Post
Tom, What temps were you seeing in the induction tubes with an ambient of 76 degrees? Also, cyl #3 & #4 have a hot exhaust pipe on either side of the intake tube so I would guess they would be more effected by the heat than cyl #1 .
John,
The intake air goes through so quickly; there is not much heat transfer. However, you bring up a good point, next time I run an engine with the cowling off, I will infrared the induction tube outer wall and make comparisons.
With the ambient temp of 76 degrees the reading was 77-78. (WOT static thrust pulls, with cowling off.). The temp. Reading was taken from #6 induction tube, thermal couple inserted .625" from tube wall. This test was to establish a baseline temperature. I was R&D testing (cc's of volume & different pump pressures) of a water injection system I was playing around with.
Thomas S.
